查看: 4405|回复: 2
[综合讨论] 运行S函数出现 flag=2 call must be a real vector of length 0错误
发表于 2009-3-25 10:59 | 显示全部楼层 |阅读模式
运行下面这个S函数,出现这种错误:
Discrete state(s) returned by S-function 'dtc' in 'untitled1/S-Function' during flag=2 call must be a real vector of length 0
以前见过是在FLAG=3的时候出现,这种情况到没遇到过,麻烦高手给看看。
function [sys,x0,str,ts] = dtcfunc1(t,x,u,flag)
switch flag==3,
  % Initialization %
  case 0,
    [sys,x0,str,ts]=mdlInitializeSizes;
  % Outputs %
  case 3,
    sys=mdlOutputs(t,x,u);
   case {1,2,4,9},
    sys=[];
  % Unexpected flags %
  otherwise
    error(['Unhandled flag = ',num2str(flag)]);
function [sys,x0,str,ts]=mdlInitializeSizes
sizes = simsizes;
sizes.NumContStates  = 0;
sizes.NumDiscStates  = 0;
sizes.NumOutputs     = 3;
sizes.NumInputs      = 1;
sizes.DirFeedthrough = 0;
sizes.NumSampleTimes = 1;   % at least one sample time is needed
sys = simsizes(sizes);
x0  = [];
str = [];
ts  = [0.001 0];
function sys=mdlOutputs(t,x,u)
u=round(u);
switch u
    case 1;
        sys(1)=0;sys(2)=1;sys(3)=1;
    case 2;
        sys(1)=0;sys(2)=0;sys(3)=1;
    case 3;
        sys(1)=1;sys(2)=0;sys(3)=1;
    case 4;
        sys(1)=1;sys(2)=0;sys(3)=0;
    case 5;
        sys(1)=1;sys(2)=1;sys(3)=0;
    case 6;
        sys(1)=0;sys(2)=1;sys(3)=0;
    case 0;
        sys(1)=0;sys(2)=0;sys(3)=0;
    otherwise
function sys=mdlGetTimeOfNextVarHit(t,x,u)
sampleTime = 1;    %  Example, set the next hit to be one second later.
sys = t + sampleTime;
function sys=mdlTerminate(t,x,u)
sys = [];
发表于 2009-3-26 09:30 | 显示全部楼层
把这个改改看怎么样
sizes.DirFeedthrough = 1;
因为你的方程没有状态变量,输出是由输入直接控制的。
发表于 2012-3-21 20:47 | 显示全部楼层
单独运行S函数是会报错,但是和Simulink结合仿真就没事了
GMT+8, 2024-12-1 10:48 , Processed in 0.061215 second(s), 18 queries , Gzip On.
