查看: 1142|回复: 0
[综合] 用双门限怎么最低检测都不到30db,高手帮忙看看
发表于 2009-3-25 10:57 | 显示全部楼层 |阅读模式
下面是我的程序,我看文献用双门限可以检测到5db左右的,问什么我连30db都检测不到,谁能告诉我是哪里出问题了吗,谢谢大家啦
[fname,pname]=uigetfile('*.wav','Open Wave File');
file=[pname,fname];
[y,fs,bits]=wavread(file);
x= awgn(y,30)
%function [x1,x2] = vad(x)
%幅度归一化到[-1,1]
x = double(x);
x = x / max(abs(x));
%常数设置
FrameLen = 240;
FrameInc = 80;
amp1 = 10;
amp2 = 2;
zcr1 = 10;
zcr2 = 5;
maxsilence = 8;  % 6*10ms  = 30ms
minlen  = 15;    % 15*10ms = 150ms
status  = 0;
count   = 0;
silence = 0;
%计算过零率
tmp1  = enframe(x(1:end-1), FrameLen, FrameInc);
tmp2  = enframe(x(2:end)  , FrameLen, FrameInc);
signs = (tmp1.*tmp2)<0;
diffs = (tmp1 -tmp2)>0.02;
zcr   = sum(signs.*diffs, 2);
%计算短时能量
amp = sum(abs(enframe(filter([1 -0.9375], 1, x), FrameLen, FrameInc)), 2);
%调整能量门限
amp1 = min(amp1, max(amp)/4);
amp2 = min(amp2, max(amp)/8);
%开始端点检测
x1 = 0;
x2 = 0;
for n=1:length(zcr)
   goto = 0;
   switch status
   case {0,1}                   % 0 = 静音, 1 = 可能开始
      if amp(n) > amp1          % 确信进入语音段
         x1 = max(n-count-1,1);
         status  = 2;
         silence = 0;
         count   = count + 1;
      elseif amp(n) > amp2 | ... % 可能处于语音段
             zcr(n) > zcr2
         status = 1;
         count  = count + 1;
      else                       % 静音状态
         status  = 0;
         count   = 0;
   case 2,                       % 2 = 语音段
      if amp(n) > amp2 | ...     % 保持在语音段
         zcr(n) > zcr2
         count = count + 1;
      else                       % 语音将结束
         silence = silence+1;
         if silence < maxsilence % 静音还不够长,尚未结束
            count  = count + 1;
         elseif count < minlen   % 语音长度太短,认为是噪声
            status  = 0;
            silence = 0;
            count   = 0;
         else                    % 语音结束
            status  = 3;
   case 3,
      break;
count = count-silence/2;
x2 = x1 + count -1;
subplot(311)
plot(x)
axis([1 length(x) -1 1])
ylabel('Speech');
line([x1*FrameInc x1*FrameInc], [-1 1], 'Color', 'red');
line([x2*FrameInc x2*FrameInc], [-1 1], 'Color', 'red');
subplot(312)
plot(amp);
axis([1 length(amp) 0 max(amp)])
ylabel('Energy');
line([x1 x1], [min(amp),max(amp)], 'Color', 'red');
line([x2 x2], [min(amp),max(amp)], 'Color', 'red');
subplot(313)
plot(zcr);
axis([1 length(zcr) 0 max(zcr)])
ylabel('ZCR');
line([x1 x1], [min(zcr),max(zcr)], 'Color', 'red');
line([x2 x2], [min(zcr),max(zcr)], 'Color', 'red');
GMT+8, 2025-1-11 14:31 , Processed in 0.066561 second(s), 17 queries , Gzip On.
