查看: 1310|回复: 4
[HHT] 请教:安装HHT程序包时出错
发表于 2009-3-15 22:11 | 显示全部楼层 |阅读模式
这是什么问题啊?
如下:
找不到 D:\Matlab\work\package_emd\EMDs\../emdc.dll.exp
找不到 D:\Matlab\work\package_emd\EMDs\../emdc.dll.lib
找不到 D:\Matlab\work\package_emd\EMDs\../emdc_fix.dll.exp
找不到 D:\Matlab\work\package_emd\EMDs\../emdc_fix.dll.lib
lcc preprocessor error: cemdc.c:19 Could not find include file <complex.h>
Error cemdc.c: .\cio.h: 31  syntax error; found `*' expecting `;'
Error cemdc.c: .\cio.h: 31  skipping `*' `y'
Error cemdc.c: .\cio.h: 39  syntax error; found `*' expecting `;'
Error cemdc.c: .\cio.h: 39  skipping `*' `pointer'
Error cemdc.c: .\cio.h: 53  syntax error; found `*' expecting `)'
Error cemdc.c: .\cio.h: 53  skipping `*' `,'
发表于 2009-3-20 18:11 | 显示全部楼层
是不是没有安装VC++
 楼主| 发表于 2009-3-20 20:45 | 显示全部楼层
回复 沙发 ziliao0815 的帖子
谢了 好像VC是有问题的,重装了下。还是有问题,如下:
lcc preprocessor error: D:\R2008B\TOOLBOX\PACKAG~1\EMDS\SRC\cemdc2_fix.c:19 Could not find include file <complex.h>
Error D:\R2008B\TOOLBOX\PACKAG~1\EMDS\SRC\cemdc2_fix.c: D:\R2008B\TOOLBOX\PACKAG~1\EMDS\SRC\cio_fix.h: 27  syntax error; found `*' expecting `;'
Error D:\R2008B\TOOLBOX\PACKAG~1\EMDS\SRC\cemdc2_fix.c: D:\R2008B\TOOLBOX\PACKAG~1\EMDS\SRC\cio_fix.h: 27  skipping `*' `y'
Error D:\R2008B\TOOLBOX\PACKAG~1\EMDS\SRC\cemdc2_fix.c: D:\R2008B\TOOLBOX\PACKAG~1\EMDS\SRC\cio_fix.h: 34  syntax error; found `*' expecting `;'
Error D:\R2008B\TOOLBOX\PACKAG~1\EMDS\SRC\cemdc2_fix.c: D:\R2008B\TOOLBOX\PACKAG~1\EMDS\SRC\cio_fix.h: 34  skipping `*' `pointer'
Error D:\R2008B\TOOLBOX\PACKAG~1\EMDS\SRC\cemdc2_fix.c: D:\R2008B\TOOLBOX\PACKAG~1\EMDS\SRC\cio_fix.h: 48  syntax error; found `*' expecting `)'
Error D:\R2008B\TOOLBOX\PACKAG~1\EMDS\SRC\cemdc2_fix.c: D:\R2008B\TOOLBOX\PACKAG~1\EMDS\SRC\cio_fix.h: 48  skipping `*' `,'
Error D:\R2008B\TOOLBOX\PACKAG~1\EMDS\SRC\cemdc2_fix.c: D:\R2008B\TOOLBOX\PACKAG~1\EMDS\SRC\cio_fix.h: 48  missing name for parameter 1 to function `add_imf'
Error D:\R2008B\TOOLBOX\PACKAG~1\EMDS\SRC\cemdc2_fix.c: D:\R2008B\TOOLBOX\PACKAG~1\EMDS\SRC\cio_fix.h: 48  syntax error; found `int' expecting `{'
Error D:\R2008B\TOOLBOX\PACKAG~1\EMDS\SRC\cemdc2_fix.c: D:\R2008B\TOOLBOX\PACKAG~1\EMDS\SRC\cio_fix.h: 48  empty declaration
Error D:\R2008B\TOOLBOX\PACKAG~1\EMDS\SRC\cemdc2_fix.c: D:\R2008B\TOOLBOX\PACKAG~1\EMDS\SRC\cio_fix.h: 48  syntax error; found `)' expecting `;'
Error D:\R2008B\TOOLBOX\PACKAG~1\EMDS\SRC\cemdc2_fix.c: D:\R2008B\TOOLBOX\PACKAG~1\EMDS\SRC\cio_fix.h: 48  skipping `)'
Error D:\R2008B\TOOLBOX\PACKAG~1\EMDS\SRC\cemdc2_fix.c: D:\R2008B\TOOLBOX\PACKAG~1\EMDS\SRC\clocal_mean2.h: 23  syntax error; found `*' expecting `)'
Error D:\R2008B\TOOLBOX\PACKAG~1\EMDS\SRC\cemdc2_fix.c: D:\R2008B\TOOLBOX\PACKAG~1\EMDS\SRC\clocal_mean2.h: 23  skipping `*' `,'
Error D:\R2008B\TOOLBOX\PACKAG~1\EMDS\SRC\cemdc2_fix.c: D:\R2008B\TOOLBOX\PACKAG~1\EMDS\SRC\clocal_mean2.h: 23  syntax error; found `double' expecting `;'
Error D:\R2008B\TOOLBOX\PACKAG~1\EMDS\SRC\cemdc2_fix.c: D:\R2008B\TOOLBOX\PACKAG~1\EMDS\SRC\clocal_mean2.h: 23  redeclaration of `complex' previously declared at D:\R2008B\TOOLBOX\PACKAG~1\EMDS\SRC\cio_fix.h 48
Error D:\R2008B\TOOLBOX\PACKAG~1\EMDS\SRC\cemdc2_fix.c: D:\R2008B\TOOLBOX\PACKAG~1\EMDS\SRC\clocal_mean2.h: 23  syntax error; found `*' expecting `;'
Error D:\R2008B\TOOLBOX\PACKAG~1\EMDS\SRC\cemdc2_fix.c: D:\R2008B\TOOLBOX\PACKAG~1\EMDS\SRC\clocal_mean2.h: 23  illegal expression
Error D:\R2008B\TOOLBOX\PACKAG~1\EMDS\SRC\cemdc2_fix.c: D:\R2008B\TOOLBOX\PACKAG~1\EMDS\SRC\clocal_mean2.h: 23  type error: pointer expected
Warning D:\R2008B\TOOLBOX\PACKAG~1\EMDS\SRC\cemdc2_fix.c: D:\R2008B\TOOLBOX\PACKAG~1\EMDS\SRC\clocal_mean2.h: 23  Statement has no effect
Error D:\R2008B\TOOLBOX\PACKAG~1\EMDS\SRC\cemdc2_fix.c: D:\R2008B\TOOLBOX\PACKAG~1\EMDS\SRC\clocal_mean2.h: 23  too many errors
  D:\R2008B\BIN\MEX.PL: Error: Compile of 'cemdc2_fix.c' failed.
Warning: <complex.h> compiler extension not found. using ANSI C implementation (slower) instead for the following files:}
> In make_emdc at 41
  In install_emd at 26
cemdc.c
cemdc_fix.c
cemdc2.c
cemdc2_fix.c
Compilation successfull.
Some codes can run faster if they are compiled with a C compiler
that handles the C99 complex data type ("complex.h"). See details above.
Installation complete. Run index_emd for a list of functions.
IMPORTANT: After running INSTALL_EMD you must run the "savepath" command to save the installation
but be careful that if you previously removed parts of the path (using e.g. the "rmpath" command)
these will be permanently removed after you run "savepath"
发表于 2009-3-24 11:26 | 显示全部楼层
添加路径了没?
 楼主| 发表于 2009-3-24 18:15 | 显示全部楼层
感谢ls两位
查了下以前的帖 好像直接添加路径 而不用安装 m文件运行是没问题的
c语言的不知道。问题基本解决了
GMT+8, 2025-1-11 14:31 , Processed in 0.059645 second(s), 17 queries , Gzip On.
