查看: 1174|回复: 0
[分形与混沌] 为什么我用小数据方法算LE4小时,还看不到图!
发表于 2009-3-9 21:04 | 显示全部楼层 |阅读模式
数据有2048个!
程序有错吗?帮忙看看!谢谢了
function lambda_1=largest_lyapunov_p3(data,N,m,tau,P,delt_t)
%function lambda_1=largest_lyapunov_exponent(data,N,m,tau,P,delt_t)
data=textread('e:/9.txt');
N=length(data);
m=12;
tau=2;
P=10;
delt_t=2;
d_length=[];
d_content=[];
Y=reconstitution(data,N,m,tau);
M=N-(m-1)*tau;
idx_j=0;
for j=1:M
    d_min=10000;
    for jj=1:M
        d_s=0;      %寻找相空间中每个点的最近距离点,并记下该点下标
        if abs(j-jj)>P                                      %限制短暂分离
            d_s=sum(abs(Y(j)-Y(jj)));
            if d_s<d_min
                d_min=d_s;
               idx_j=jj;
    if ((M-j)>(M-idx_j));%计算点j的最大演化时间步长i
        max_i=M-idx_j;
    else
        max_i=M-j;
    d_length=[d_length,max_i];
    for k=1:max_i              %计算点j与其最近邻点在i个离散步后的距离
        d_j_i=0;
        d_j_i=norm(Y(j+k)-Y(idx_j+k));
        d_content=[d_content,d_j_i];
%对每个演化时间步长i,求所有的j的lnd(i,j)平均
y=[];
for i=1:max(d_length)
   S_j_i=0;
   sum_former=0;
   Count=0;
   for j=1:M
       if j==1
          former=0;
       else
          former=d_length(j-1);
       sum_former=sum_former+former;
       if i<=(d_length(j))
           if d_content(sum_former+i)~=0
              S_j_i=S_j_i+log(d_content(sum_former+i));
              Count=Count+1;
   y=[y,S_j_i/(Count*delt_t)]; %对每个演化时间步长i,求所有的j平均
XX=1:length(y);
figure;
plot(XX,y(XX),'-','markersize',1);hold on;%——————————【上面的图是从这儿画出来的】
linear=input('请输入线形部分的长度');
XX1=1:linear;
pp=polyfit(XX1,y(XX1),1);
lambda_1=pp(1)
yp=polyval(pp,XX1);
figure;
plot(XX1,yp,'r--');
GMT+8, 2025-1-9 00:03 , Processed in 0.074807 second(s), 17 queries , Gzip On.
