查看: 5130|回复: 5
请教!初始应力平衡问题?
发表于 2009-3-4 21:26 | 显示全部楼层 |阅读模式
在计算固结过程中,先进行地应力平衡。
过程为,先建立模型,将上部填土去掉,利用单元生死,进行计算,可以得到结果。
将结果导入成为***.csv文件后,利用
initial conditions,type=stress,input=***.csv来添加关键词,再次提交并计算。
结果出现如下问题:
The job input file "Job-1.inp" has been submitted for analysis.
Error in job Job-1: in keyword *INITIALCONDITIONS, file "Job-1.inp", line 101124: Unknown assembly id 1.
Error in job Job-1: in keyword *INITIALCONDITIONS, file "Job-1.inp", line 101124: Unknown assembly id 2.
Error in job Job-1: in keyword *INITIALCONDITIONS, file "Job-1.inp", line 101124: Unknown assembly id 3.
Error in job Job-1: in keyword *INITIALCONDITIONS, file "Job-1.inp", line 101124: Unknown assembly id 4.
Error in job Job-1: in keyword *INITIALCONDITIONS, file "Job-1.inp", line 101124: Unknown assembly id 5.
Error in job Job-1: in keyword *INITIALCONDITIONS, file "Job-1.inp", line 101124: Unknown assembly id 6.
Error in job Job-1: in keyword *INITIALCONDITIONS, file "Job-1.inp", line 101124: Unknown assembly id 7.
Error in job Job-1: in keyword *INITIALCONDITIONS, file "Job-1.inp", line 101124: Unknown assembly id 8.
Error in job Job-1: in keyword *INITIALCONDITIONS, file "Job-1.inp", line 101124: Unknown assembly id 9.
Error in job Job-1: in keyword *INITIALCONDITIONS, file "Job-1.inp", line 101124: Unknown assembly id 10.
Error in job Job-1: in keyword *INITIALCONDITIONS, file "Job-1.inp", line 101124: Unknown assembly id 11.
Error in job Job-1: in keyword *INITIALCONDITIONS, file "Job-1.inp", line 101124: Unknown assembly id 12.
Error in job Job-1: in keyword *INITIALCONDITIONS, file "Job-1.inp", line 101124: Unknown assembly id 13.
Error in job Job-1: in keyword *INITIALCONDITIONS, file "Job-1.inp", line 101124: Unknown assembly id 14.
Error in job Job-1: in keyword *INITIALCONDITIONS, file "Job-1.inp", line 101124: Unknown assembly id 15.
Error in job Job-1: in keyword *INITIALCONDITIONS, file "Job-1.inp", line 101124: Unknown assembly id 16.
Error in job Job-1: in keyword *INITIALCONDITIONS, file "Job-1.inp", line 101124: Unknown assembly id 17.
Error in job Job-1: in keyword *INITIALCONDITIONS, file "Job-1.inp", line 101124: Unknown assembly id 18.
Error in job Job-1: in keyword *INITIALCONDITIONS, file "Job-1.inp", line 101124: Unknown assembly id 19.
Error in job Job-1: in keyword *INITIALCONDITIONS, file "Job-1.inp", line 101124: Unknown assembly id 20.
Job Job-1: Analysis Input File Processor aborted due to errors.
Error in job Job-1: Analysis Input File Processor exited with an error.
Job Job-1 aborted due to errors.
请教,,,什么原因?不胜感激
发表于 2009-3-6 11:14 | 显示全部楼层
看看英文,说的是未知的id
你加载的set可能不存在,或者节点号不对
 楼主| 发表于 2009-3-6 11:38 | 显示全部楼层
解决了,谢谢
问题是不存在set
发表于 2009-3-10 10:11 | 显示全部楼层
那就是你在csv中所述节点号在你的题目中没有!
另外你看看 line 101124是什么??
发表于 2019-7-12 11:22 | 显示全部楼层
前辈,你好,我在应力场导入时使用initial conditions,type=stress,input=***.csv,也出现了同样的问题,请问你是怎么解决的?
发表于 2019-12-18 15:00 | 显示全部楼层
红酒的出现领会了很多贵族都想不到的想法,尤其是品酒的瞬间可以享受这款游戏带来的乐趣北京pk10游戏的来源出自北京娱乐爱好者的构思想法,当时有人拿着红酒去享受游戏时刻不停反复想出这类游戏的画面极速飞艇这是第二款游戏的出现,带来当时的权益收益达到35%的返佣思想,带给人们一类开心而开了的思想权贵重庆欢乐生肖不但贵重的红酒引来的构思还给权益带来无数的欢迎掌声。此外参加游戏还立送30%的面值余额。还有月月反最高35%。欢迎来摸索!我是甜心。
GMT+8, 2024-12-27 21:12 , Processed in 0.095271 second(s), 18 queries , Gzip On.
