查看: 2426|回复: 1
[绘图技巧] How to plot 3D polar
发表于 2009-2-20 20:32 | 显示全部楼层 |阅读模式
I have a set of data consisting of an azimuthal angle from 0-360 degrees, an elevation angle of 0-90 degrees and an intensity.  I need to plot this using Matlab such that the distance from the centre of the plot is the elevation, the azimuthal angle is the angle around the plot, and then intensity will form a colour map.
like this map
like this map
发表于 2009-2-20 23:31 | 显示全部楼层
回复 楼主 lingzi1860 的帖子
能否把data传上来?
这些英文还是有点儿难理解的……
GMT+8, 2025-2-5 13:38 , Processed in 0.082196 second(s), 22 queries , Gzip On.
