查看: 2405|回复: 1
[ADAMS专区] adams/car仿真失败, 求高人指点
发表于 2009-2-20 11:57 | 显示全部楼层 |阅读模式
用adams/car做整车仿真, 模型用的是adams自带的, 进行simulate 的时候出现一系列ERROR:
Input Phase - Reading in Model
   Adams/Solver dataset Title:
   Adams/Car Assembly (MD R2 Adams)
ERROR:  Found an unexpected token while looking for a comma or end of statement.
ERROR:     Statement           : SPLINE
ERROR:     Argument            : Y
ERROR:     Value number        : 1
ERROR:     Statement at line   : 9186
ERROR:     Error at line       : 9188
ERROR:     Error line text     : ', Y = 1.[[#]]QNAN, 1.#QNAN, 1.#QNAN, 1.#QNAN, 1.#QNAN, 1.#QNAN, 1.#QNAN, 1.#QNAN'
ERROR:     Error token text    : '#'
ERROR:     Error token type    : unknown character
ERROR:  Errors in the Adams dataset prevent it from being loaded into the database.
   Reading of model complete.
   Adams/Car MD R2 Adams
Processing ENVIRONMENT entries in 'D:\ADAMS2007R2\Adams\MDR2\acar/acar.cfg'
Processing ENVIRONMENT entries in 'C:\Documents and Settings\Acer/.acar.cfg'
ERROR:  There is no corresponding object for this lookup index.
ERROR:     Error type:  ae_lookup_object_index
Input Phase - Populating Solver database
---- ERROR ----
   Error(s) found in input, no model available.
   Input Phase Complete.
   CPU time is 0.20312 seconds.
---- ERROR ----
   An error has been found in the model dataset supplied
   through the FILE/MODEL command.  Dataset file name is:
   workshop1a_ilc.adm
   Enter Command:
   string/3, string=workshop1a_ilc.xml
---- ERROR ----
   STRING/3 has not been defined in the input data.
   Enter Command:
   preferences/solver=F77
   Enter Command:
   output/nosep
   Enter Command:
   control/ routine=abgVDM::EventInit, function=user(3,1,9,0,2,7,7,16)
---- ERROR ----
   No model is present in memory at this instant.
   Read in an Adams/Solver data set first.
   Enter Command:
   control/ routine=abgVDM::EventRunAll, function=user(0)
---- ERROR ----
   Enter Command:
   Enter Command:
   stop
   Terminating Adams/Car usersubs...
   Adams/Solver execution terminated by subprogram A3TERM
   CPU time used = 0.21875 seconds
ERROR: Cannot load results!  File 'workshop1a_ilc.res' not found.
ERROR: Cannot load graphics!  File 'workshop1a_ilc.gra' not found.
Simulation is complete.
请高人指点原因及解决方法!
发表于 2009-10-14 15:24 | 显示全部楼层
怎么没人回答的啊?
楼主解决没,解决了跟我说说原因啊,我邮箱是wwm19851128@126.com
GMT+8, 2025-1-1 11:39 , Processed in 0.057195 second(s), 18 queries , Gzip On.
