查看: 1143|回复: 1
[图像处理] ostu求阈值怎么老出错
发表于 2009-2-15 10:56 | 显示全部楼层 |阅读模式
x=imread('QRcode.jpg');
%figure;
%imshow(x);
[m,n]=size(x);
N=m*n;
num=zeros(1,256);%生成一个1*256的全0矩阵%
p=zeros(1,256);
for i=1:m
     for j=1:n
         num(x(i,j)+1)=num(x(i,j)+1)+1;
for i=0:255;
     p(i+1)=num(i+1)/N;%计算灰度值为i的像素点出现的概率%
totalmean=0;
for i=0:255;
     totalmean=totalmean+i*p(i+1);%总体的均值%
maxvar=0;
for k=0:255
     kk=k+1;
     zerosth=sum(p(1:kk));
     firsth=0;
     for h=0:k
         firsth=firsth+h*p(h+1);
     var=totalmean*zerosth-firsth;
     var=var*var;
     var=var/(zerosth*(1-zerosth)+0.01);
     var=sqrt(var);
     if(var>maxvar)
         maxvar=var;
         point=k;
threshold=point
这是用ostu求图像二值化阈值的,一运行就显示??? Error using ==> +
Function '+' is not defined for values of class 'uint8'.
Error in ==> c:\MATLAB6p5\work\Untitled12.m
On line 12  ==>          num(x(i,j)+1)=num(x(i,j)+1)+1;
我把 num(x(i,j)+1)=num(x(i,j)+1)+1;改为   num(x(i,j))=num(x(i,j))+1;又显示??? Subscript indices must either be real positive integers or logicals.
On line 12  ==>          num(x(i,j))=num(x(i,j))+1
我觉得线标没有超出范围啊,可就是不对,请问哪位高手会吗
发表于 2009-2-15 13:59 | 显示全部楼层
感觉楼主三个帖是相同一个问题! 是吗?
可否帮LZ合成一帖, 方便大家容易了解状况!
GMT+8, 2025-1-12 08:09 , Processed in 0.065200 second(s), 21 queries , Gzip On.
