查看: 1464|回复: 0
[基础理论] table表中的数据?
发表于 2009-1-15 15:30 | 显示全部楼层 |阅读模式
/batch,list
/verify,dv-1101c
/title, dv-1101c, Flotran Remeshing: Cylinder pass through a channel
/COM,****************************************************
/COM,* Cylinder pass through a channel (pure fluid flow)
/COM,* Verify partial domain re-meshing
r1 = 2.5
l1 = 5.0
l2= 20.0
l3=60.0
h = 10.0
rx0= l1+(l2-l1)/2.0
ry0 = h/2.0
nl1 = 5
nl3 = 10
nr=8
nc=8
/PREP7
*DEL,_FNCNAME
*DEL,_FNCMTID
*DEL,_FNC_C1
*SET,_FNCNAME,'DIS'
*DIM,_FNC_C1,,1
*SET,_FNC_C1(1),1.0
! /INPUT,force.func
*DIM,%_FNCNAME%,TABLE,6,3,1
! Begin of equation: a*{TIME}
*SET,%_FNCNAME%(0,0,1), 0.0, -999
*SET,%_FNCNAME%(2,0,1), 0.0
*SET,%_FNCNAME%(3,0,1), %_FNC_C1(1)%
*SET,%_FNCNAME%(4,0,1), 0.0
*SET,%_FNCNAME%(5,0,1), 0.0
*SET,%_FNCNAME%(6,0,1), 0.0
*SET,%_FNCNAME%(0,1,1), 1.0, -1, 0, 1, 17, 3, 1
*SET,%_FNCNAME%(0,2,1), 0.0, 99, 0, 1, -1, 0, 0
*SET,%_FNCNAME%(0,3,1),   0
! End of equation: a*{TIME}
RECTNG,0,l1,0,h,
RECTNG,l1,l2,0,h,
RECTNG,l2,l3,0,h,
aglue,all
CYl4,rx0,ry0,0,45,r1,135
CYl4,rx0,ry0,0,135,r1,225
CYl4,rx0,ry0,0,225,r1,315
CYl4,rx0,ry0,0,315,r1,405
asel,s,,,2
asel,a,,,3
asel,a,,,6
asel,a,,,7
allsel,below,area
aglue,all
allsel
FLST,3,4,5,ORDE,3
FITEM,3,2
FITEM,3,8
FITEM,3,-10
ASBA,       4,P51X
aplot
et,1,141
KEYOPT,1,4,1
type,1
mat,1
asel,s,,,1
esize,.5
mshape,1,2d
mshkey,0
amesh,all
et,2,141
KEYOPT,2,4,1
type,2
mat,1
asel,s,,,3
esize,.5
mshape,1,2d
mshkey,0
amesh,all
et,3,141
KEYOPT,3,4,1
type,3
mat,1
asel,s,,,5
esize,2.0
mshape,1,2d
mshkey,0
amesh,all
nsel,s,loc,x,0
D,ALL,VX,0.0,
D,ALL,VY, 0.0
D,ALL,UX,0.0,
D,ALL,UY, 0.0
nsel,s,loc,x,l3
D,ALL,pres,0.0
D,ALL,UX,0.0,
D,ALL,UY, 0.0
nsel,s,loc,y,0
D,ALL,vy,0.0
D,ALL,UX,0.0,
D,ALL,UY, 0.0
nsel,s,loc,y,h
D,ALL,vy,0.0
D,ALL,UX,0.0,
D,ALL,UY,0.0,
lsel,s,,,5
lsel,a,,,23
lsel,a,,,25
lsel,a,,,27
nsll,s,1
d,all,UX,%DIS%
d,all,UY,0.0
d,all,VX,1.0
d,all,VY,0.0
allsel
cdwrite,db,fluid,cdb,
fini
! Flotran Setup
/solu
FLDATA30,QUAD,MOMD,2,
FLDATA30,QUAD,MOMS,2,
FLDATA30,QUAD,PRSD,2,
FLDATA30,QUAD,PRSS,2,
FLDATA30,QUAD,THRD,0,
FLDATA30,QUAD,THRS,0,
FLDATA30,QUAD,TRBD,0,
FLDATA30,QUAD,TRBS,2,
/solu
FLDATA4,TIME,NUMB,100000,
FLDATA4,TIME,TEND,44.0,
FLDA,SOLU,ALE,T                ! ALE solution
FLDATA1,SOLU,FLOW,1
FLDATA1,SOLU,TRAN,1
!FLDATA1,SOLU,TURB,1
FLDATA2,TIME,GLOB,5
FLDATA7,PROT,DENS,CONSTANT
FLDATA8,NOMI,DENS,1.0
FLDATA7,PROT,VISC,CONSTANT
FLDATA8,NOMI,VISC,1.0
!FLDA,BULK,BETA,1.0e5
FLDA,TIME,STEP, 2.0
!!! Newmark method
FLDATA,OUTP,TAUW,T
FLDATA,TIME,METH,NEWM
FLDATA,TIME,DELT,0.5
!! Set ANSYS-STRUCTURE commands
SAVE
/COM
/COM  Re-meshing Commands
/COM
FLDATA,REMESH,ELEM,ALL        ! all defined element re-meshing
FLDATA,REMESH,ARMA,10.0       ! maximum aspect ratio
FLDATA,REMESH,VOCH,5.0        ! maximum volume change
FLDATA,REMESH,ARCH,5.0        ! maximum aspect ratio change
SOLVE
SAVE
finish
哪位知道定义的table里的数据分别代表什么?
GMT+8, 2025-2-20 12:06 , Processed in 0.144356 second(s), 17 queries , Gzip On.
