查看: 2613|回复: 6
[编程技巧] [求助]hinfsyn命令怎么用啊?!
发表于 2006-2-27 16:42 | 显示全部楼层 |阅读模式
我要用hinfsyn命令设计一个H无穷控制器,命令如下:
[k,g,gfin,ax,ay,hamx,hamy] =hinfsyn(p,1,1,0,10,0.0001,1).主要是控制对象P怎么输入?
p=(a;b1 b2;c1 d11 d12;c2 d21 d22)的形式.
我输入的不对,matlab提醒我不是system matrix.
请问如何正确输入p?下面是我的p:
a=[0,0,0,0,0,0,1,0,0,0,0,0;
0,0,0,0,0,0,0,1,0,0,0,0;
0,0,0,0,0,0,0,0,1,0,0,0;
0,0,0,0,0,0,0,0,0,1,0,0;
0,0,0,0,0,0,0,0,0,0,1,0;
0,0,0,0,0,0,0,0,0,0,0,1;
-17910.47,0,0,0,0,0,-0.80298,0,0,0,0,0;
0,-234623.98,0,0,0,0,0,-2.90628,0,0,0,0;
0,0,-1138702.41,0,0,0,0,0,-6.4026,0,0,0;
0,0,0,-3543306.28,0,0,0,0,0,-11.2942,0,0;
0,0,0,0,0,-8587478.59,0,0,0,0,-17.5826,0;
0,0,0,0,0,-17735131.92,0,0,0,0,0,-25.2679];
b1=[0;0;0;0;0;0;-1.44e-6;-1.09e-5;-3.68e-5;-8.7e-5;-1.7e-4;-2.95e-4];
b2=b1;
c1=[1,0,0,0,0,0,0,0,0,0,0,0;0,1,0,0,0,0,0,0,0,0,0,0;0,0,1,0,0,0,0,0,0,0,0,0;0,0,0,1,0,0,0,0,0,0,0,0;0,0,0,0,1,0,0,0,0,0,0,0;0,0,0,0,0,1,0,0,0,0,0,0;0,0,0,0,0,0,0,0,0,0,0,0;0,0,0,0,0,0,0,0,0,0,0,0;0,0,0,0,0,0,0,0,0,0,0,0;0,0,0,0,0,0,0,0,0,0,0,0;0,0,0,0,0,0,0,0,0,0,0,0;0,0,0,0,0,0,0,0,0,0,0,0;0,0,0,0,0,0,0,0,0,0,0,0;0,0,0,0,0,0,0,0,0,0,0,0;0,0,0,0,0,0,0,0,0,0,0,0];
c2=[-29.92,-227.37,-765.88,-1818.95,-3548.16,-6132.99,0,0,0,0,0,0];
d11=[0;0;0;0;0;0;0;0;0;0;0;0;0.78e-8;0;0];
d12=[0;0;0;0;0;0;0;0;0;0;0;0;0.78e-8;1.2e-2;4.78e-007];
d21=0.033;
d22=0.033;
 楼主| 发表于 2006-2-27 16:46 | 显示全部楼层
sorry!
sorry!
我发的C1太长,C1修改如下:
发表于 2006-2-27 19:29 | 显示全部楼层
回复:(tianfen)[求助]hinfsyn命令怎么用啊?!
你的输入好像对不上吧
 楼主| 发表于 2006-2-27 22:22 | 显示全部楼层
可以的,我试过,各部分矩阵都是符合维度的,用p=(a b1 b2;c1 d11 d12;c2 d21 d22)可以得到一个矩阵的.不过就是用hinfsyn时不行啊!
发表于 2006-2-28 09:00 | 显示全部楼层
看了一下这个错误是检查你的p矩阵是否是系统矩阵造成的
对于控制理论不太熟悉不知道什么样是系统矩阵
在matlab检查是否是系统矩阵是有minfo这个函数完成的
你可以doc minfo看看
 楼主| 发表于 2006-2-28 15:35 | 显示全部楼层
呵呵,先谢谢了。我问过我师兄,他也不会,我先看看帮助吧,估计还是不会。
 楼主| 发表于 2006-2-28 15:52 | 显示全部楼层
呵呵。我把它改成了:
b=[b1 b2];
c=[c1;c2];
d=[d11 d12; d21 d22];
p=pck(a,b,c,d) 就有结果了,不过不知道这个结果对不对。
GMT+8, 2025-1-19 14:38 , Processed in 0.059958 second(s), 21 queries , Gzip On.
