查看: 1124|回复: 1
[综合讨论] s2y用法
发表于 2008-12-17 11:02 | 显示全部楼层 |阅读模式
请问在用s2y命令时,s是以dB为单位的,还是用实部+虚部形式的?
发表于 2008-12-17 11:26 | 显示全部楼层
doc s2y
you'll get:
s2y
Convert S-parameters to Y-parameters
Syntax
y_params = s2y(s_params,z0)
Description
y_params = s2y(s_params'z0) converts the scattering parameters s_params into the admittance parameters y_params. The s_params input is a complex n-by-n-by-m array, representing m n-port S-parameters. z0 is the reference impedance; its default is 50 ohms. y_params is a complex n-by-n-by-m array, representing m n-port Y-parameters
GMT+8, 2025-1-26 11:49 , Processed in 0.166364 second(s), 17 queries , Gzip On.
