查看: 1822|回复: 2
[编程技巧] 请教:如何构造hankel矩阵
发表于 2008-12-14 21:00 | 显示全部楼层 |阅读模式
比如我有一列数据或几列数据,我想构造一个hankel矩阵怎么做,我想问的是如何控制hankel矩阵的维数。
不是直接hankel一下了事。
发表于 2008-12-15 13:09 | 显示全部楼层
Hankel
Hankel matrix
Syntax
H = hankel(c)
H = hankel(c,r)
Description
H = hankel(c) returns the square Hankel matrix whose first column is c and whose elements are zero below the first anti-diagonal.
H = hankel(c,r) returns a Hankel matrix whose first column is c and whose last row is r. If the last element of c differs from the first element of r, the last element of c prevails.
Definition
A Hankel matrix is a matrix that is symmetric and constant across the anti-diagonals, and has elements h(i,j) = p(i+j-1), where vector p = [c r(2:end)] completely determines the Hankel matrix.
Examples
A Hankel matrix with anti-diagonal disagreement is
c = 1:3; r = 7:10;
h = hankel(c,r)
h =
    1    2    3    8
    2    3    8    9
    3    8    9   10
p = [1 2 3 8 9 10]
 楼主| 发表于 2008-12-15 16:55 | 显示全部楼层
谢谢你!
这个我看了,关键是还是不懂。
比如:我有3列数据,想用这三列构造一个hankel矩阵,怎么控制维数,主要是列数控制,比如我需要构造为10列的hankel矩阵。
直接hankel的话,hankel矩阵的行数=列数=原矩阵的行数*列数
GMT+8, 2025-1-26 11:51 , Processed in 0.173838 second(s), 17 queries , Gzip On.
