查看: 1019|回复: 0
[结构分析] 求助!地震波输入出现问题
发表于 2008-12-12 00:29 | 显示全部楼层 |阅读模式
命令流如下,用来读取地震波数据
  1. /prep7
  2. *dim,accex,array,4200,1
  3. *dim,accey,array,4200,1
  4. *dim,accez,array,4200,1
  5. *create,temp1,mac
  6. *vread,accex(1,1),'accex','txt','G:\',IJK,4200,,
  7. (e17.6,e15.6,e15.6,e15.6,e15.6)
  8. *end
  9. /input,temp1
  10. *create,temp2,mac
  11. *vread,accey(1,1),'accey','txt','G:\',IJK,4200,,
  12. (e17.6,e15.6,e15.6,e15.6,e15.6)
  13. *end
  14. /input,temp2
  15. *create,temp3
  16. *vread,accez(1,1),'accez','txt','G:\',IJK,4200,,
  17. (e17.6,e15.6,e15.6,e15.6,e15.6)
  18. *end
  19. /input,temp3
  20. finish
运行后出现提示:
*** WARNING ***
File temp1 does not exist.
The /INPUT command is ignored
*** WARNING ***
File temp2 does not exist.
我按照书上说的也把这三个宏文件放在各个指定路径下了,可运行后还是出现这种错误,不知道哪位前辈能指点一下,谢谢
GMT+8, 2025-1-12 20:00 , Processed in 0.093745 second(s), 19 queries , Gzip On.
