查看: 1684|回复: 0
[Marc专区] 定义属性出错,如何解决?
发表于 2008-11-29 22:27 | 显示全部楼层 |阅读模式
Warning reported from application APP INTERFACES
$#     No element properties have been assigned to the element with id = 20361
这个是我在给划分好网格后的平面,定义板的属性时,系统给出的出错信息,就是这个单元和这个平面没有关联,我想把这个单元和平面Associate时,又给出下面信息$# 0 node(s) have been associated to vertices.
$# 1 node(s) are already associated to edges.
$# 0 node(s) have been associated to edges.
$# 1 node(s) are already associated to surfaces interior.
$# 0 node(s) have been associated to surfaces interior.
$# 0 node(s) associated to 1 surface(s):  Surface 20262,这个平面号是20262。
那位高手能帮忙解决一下,主要就是在网格划分好后,定义属性时,该几何体内的部分单元和这个几何体不关联,其他单元属性都定义成功。怎么给那些不成功的单元定义属性?谢谢
GMT+8, 2025-1-17 12:05 , Processed in 0.074138 second(s), 17 queries , Gzip On.
