查看: 1253|回复: 6
[图像处理] 我的程序为什么运行不了呢?
发表于 2008-11-27 08:06 | 显示全部楼层 |阅读模式
一个图像颜色处理程序:
h0=figure('toolbar','none',...'position',[198 56 350 468],...'name','
实例');
h1=axes('parent',h0,...'position',[0.12 0.45 0.75
0.5],...'visible','off');
I=imread('123.tif');
imshow(I)
b1=uicontrol
('parent',h0,...'units','points',...'tag','b1',...'style','pushbutton
',...'string','减少颜色',...'backgroundcolor',[0.75 0.75
0.75],...'position',[30 100 50 20],...'callback',
[...'cla,',...'[X,map]=imread(''123.tif'');,',...'[Y,map2]
=imapprox(X,map,64);,',...'image(Y),',...'colormap(map2)']);
b2=uicontrol
('parent',h0,...'units','points',...'tag','b2',...'style','pushbutton
',...'string','颜色抖动',...'backgroundcolor',[0.75 0.75
0.75],...'position',[100 100 50 20],...'callback',
[...'cla,',...'I=imread(''123.tif'');,',...'[X,map]=rgb2ind
(I,128,''nodither'');,',...'imshow(X)']);
b3=uicontrol
('parent',h0,...'units','points',...'tag','b3',...'style','pushbutton
',...'string','颜色变换一',...'backgroundcolor',[0.75 0.75
0.75],...'position',[170 100 50 20],...'callback',
[...'cla,',...'I=imread(''123.tif'');,',...'Y=rgb2ntsc
(I);,',...'J=Y(:,:,1);,',...'imshow(J)']);
b4=uicontrol
('parent',h0,...'units','points',...'tag','b4',...'style','pushbutton
',...'string','关闭',...'backgroundcolor',[0.75 0.75
0.75],...'position',[170 50 50 20],...'callback','close');
b5=uicontrol
('parent',h0,...'units','points',...'tag','b5',...'style','pushbutton
',...'string','颜色变换三',...'backgroundcolor',[0.75 0.75
0.75],...'position',[100 50 50 20],...'callback',
[...'cla,',...'I=imread(''123.tif'');,',...'J=rgb2ycbcr
(I);,',...'imshow(J)']);
b6=uicontrol
('parent',h0,...'units','points',...'tag','b6',...'style','pushbutton
',...'string','颜色变换二',...'backgroundcolor',[0.75 0.75
0.75],...'position',[30 50 50 20],...'callback',
[...'cla,',...'I=imread(''123.tif'');,',...'J=rgb2hsv
运行以后是:
??? 实例');
Error: Missing variable or function.
请哪位大侠指点一二...
发表于 2008-11-27 10:57 | 显示全部楼层
实例');
写成一行
发表于 2008-11-27 21:31 | 显示全部楼层
回复 楼主 wangzhe860923 的帖子
LZ提供的程序有点儿乱,是从m文件中直接复制出来的吗?
 楼主| 发表于 2008-11-28 07:45 | 显示全部楼层
回复 沙发 sigma665 的帖子
我试试!谢谢你啊
回复 板凳 ch_j1985 的帖子
是啊 ,有点什么不对吗?
发表于 2008-11-28 21:46 | 显示全部楼层
回复 5楼 wangzhe860923 的帖子
呵呵,没有什么不对的,只是看起来比较费力!
发表于 2008-11-29 19:28 | 显示全部楼层
好乱,眼都花了
GMT+8, 2025-1-26 12:00 , Processed in 0.085842 second(s), 17 queries , Gzip On.
