查看: 2265|回复: 2
[健康监测] Null subspace-based damage detection of structures using ...
发表于 2006-2-22 15:44 | 显示全部楼层 |阅读模式
  Null subspace-based damage detection of structures using vibration measurements
  Yan, A.-M.
  , Golinval, J.-C.
  Department of Aerospace, Mechanics and Materials, Vibration and Identification of Structures, University of Liege, Chemin des Chevreuils 1, B52, B-4000 Liege, Belgium
  Abstract
  A damage detection method of mechanical system based on subspace identification concepts and statistical process techniques is presented. The aim is to propose a method that is sensitive to small-sized structural damages and suitable for on-line monitoring. Measured time-responses of structures subjected to artificial or environmental vibrations are assembled to form the Hankel matrix, which is further factorised by performing singular-value decomposition to obtain characteristic subspaces. It may be demonstrated that the structural responses are mainly located in the active subspace defined by the first principal components, which is orthonormal to the null subspace defined by the remaining principal components. If no structural damage occurs, the orthonormality relation between the subspaces remains valid with small residues when consecutive data sets are compared, and these residues may be evaluated by the proposed damage indicators. The method is validated using an experimental mock-up of an airplane subjected to different levels of damages simulated. It is also applied in environmental vibration testing of a street lighting device to monitor structural fatigue evolution. © 2005 Elsevier Ltd. All rights reserved.
发表于 2008-6-8 20:34 | 显示全部楼层
文章的中文翻译
请教各位大侠,本人英语水平无法读懂,哪位大侠发下以上文章的中文翻译啊 !
[ 本帖最后由 fengchunlijdb 于 2008-6-10 09:58 编辑 ]
发表于 2008-6-10 09:59 | 显示全部楼层
:@L 我也想知道楼主说的是啥
GMT+8, 2025-1-11 22:54 , Processed in 0.068822 second(s), 18 queries , Gzip On.
