查看: 2233|回复: 2
[计算数学] 求助符号函数方程问题
发表于 2008-11-19 22:00 | 显示全部楼层 |阅读模式
function d1()
fid=fopen('d1.txt','w');
syms x y f o w
for x=0.5:0.5:10
    eqn=(1193.662074+1193.662074*i)*besselj(1,(.2513274122e-1+.2513274122e-1*i)*x^.5)/x^1.5/besselj(0,(.2513274122e-1+.2513274122e-1*i)*x^.5)/y/(1+(113.1768484+113.1768484*i)*besselj(1,(.2513274122e-1+.2513274122e-1*i)*x^.5)/x^1.5/besselj(0,(.2513274122e-1+.2513274122e-1*i)*x^.5)*log(1+1350.000000/(1.341640787+y^.5)^2))+(1.8-y)/(1.8+y);
    eq=vpa(eqn,4);
    f=solve(eq,y);
    fprintf(fid,'%f',x);
    fprintf(fid,'%s','      ');
    fprintf(fid,'%f',double(real(f)));
    fprintf(fid,'%f',double(imag(f)));
    fprintf(fid,'%s\n','');
    clear maplemex;
sta=fclose(fid);
运行后出现
Warning: Explicit solution could not be found.
> In solve at 140
  In sym.solve at 49
  In d1 at 6
??? Function 'eval' is not defined for values of class 'double'.
Error in ==> eval at 44
  [varargout{1:nargout}] = builtin('eval', varargin{:});
Error in ==> sym.double at 45
D = reshape(eval(X),siz);
Error in ==> d1 at 9
但是在maple中是有解的,
请高手帮忙!
发表于 2008-11-20 09:59 | 显示全部楼层
回复 楼主 wzpedison 的帖子
我这里直接运行到死机了,
matlab的符号计算功能比maple的差远了,是不是这个方程在matlab里面找不到解呢?
发表于 2008-11-20 15:07 | 显示全部楼层
还是推荐maple求解,能有结果不就可以了么?
GMT+8, 2025-1-9 00:14 , Processed in 0.089154 second(s), 18 queries , Gzip On.
