查看: 1834|回复: 2
[材料与接触] 接触分析中出现这样的错误提示
发表于 2008-11-19 09:43 | 显示全部楼层 |阅读模式
*** WARNING ***                         CP =    1993.766   TIME= 22:31:55
Some contact elements on contact surface specified by real constant set
19 belong to symmetric contact, some do not.
*** ERROR ***                           CP =    3306.734   TIME= 22:56:04
Preconditioned conjugate gradient solver error level 1.  Possibly, the
model is unconstrained or additional iterations may be needed.  Try
running with a multiplier MULT > 1 in EQSLV command (3 > MULT > 1).
*** WARNING ***                         CP =    3307.109   TIME= 08:52:28
The unconverged solution (identified as time 2 substep 999999) is
output for analysis debug purposes.  Results should not be used for
any other purpose.
发表于 2008-11-19 13:25 | 显示全部楼层
你好好看一下提示,错误提示已经很清楚了,你所作的就是将错误提示翻译过来,然后照着提示来做。
发表于 2010-4-6 17:00 | 显示全部楼层
不收敛因素很多,从错误提示中很难找出具体的原因,建议对边界条件的设置进行检查
GMT+8, 2025-1-11 22:53 , Processed in 0.103026 second(s), 18 queries , Gzip On.
