查看: 2119|回复: 0
[Fluent应用] 单机多核并行计算的问题
发表于 2008-10-23 13:16 | 显示全部楼层 |阅读模式
我在用一个四核工作站计算一个DPM的模拟,打开并行设置后,像单核一样开始进行进算,结果运行两个时间步长之后就罢工了,在单核下运算顺利就是速度慢点,所以基本问题就在多核并行设置上,以下是命令串口的内容,附件是全部内容。请各位高手指点一下错误的地方,谢谢!(我设置的balance interval 为8):
Parallel particle tracking concurrency: 0%
iter continuity x-velocity y-velocity z-velocity     energy          k    epsilon        h2o     time/iter
! 1751 solution is converged
1751 2.9539e-06 2.6854e-04 1.2976e-04 6.5996e-05 4.2060e-08 5.1566e-08 5.0939e-08 7.3039e-04  0:00:37   20
>> Dividing domain into 64 partitions using Cartesian Axes.
.................................................. 50
............. 63 bisections.
  Smoothing partition boundaries...
  Time = 0.567145 seconds.
  Done.
>> 64 Stored Partitions:
  Collective Partition Statistics:        Minimum   Maximum   Total
The Parallel FLUENT process could not be started.
  Cell count                   Cell count                              3138      3143      201000
  Mean cell count deviation               -0.1%     0.1%
GMT+8, 2024-11-25 16:41 , Processed in 0.062825 second(s), 17 queries , Gzip On.
