查看: 1658|回复: 4
[GUI界面] 关于GUI的按钮问题
发表于 2008-10-20 18:29 | 显示全部楼层 |阅读模式
请教各位大侠我用mesh画的图为什么图可以显示出来但是等图显示出来按钮却看不见了
程序如下
function varargout = yaoyao(varargin)
gui_Singleton = 1;
gui_State = struct('gui_Name',       mfilename, ...
                   'gui_Singleton',  gui_Singleton, ...
                   'gui_OpeningFcn', @yaoyao_OpeningFcn, ...
                   'gui_OutputFcn',  @yaoyao_OutputFcn, ...
                   'gui_LayoutFcn',  [] , ...
                   'gui_Callback',   []);
if nargin && ischar(varargin{1})
    gui_State.gui_Callback = str2func(varargin{1});
if nargout
    [varargout{1:nargout}] = gui_mainfcn(gui_State, varargin{:});
else
function yaoyao_OpeningFcn(hObject, eventdata, handles, varargin)
global A
global z1
global z2
global kc
global kr
global ha_c
global hf_c
global c_c
global c2
handles.output = hObject;
guidata(hObject, handles);
function varargout = yaoyao_OutputFcn(hObject, eventdata, handles)
varargout{1} = handles.output;
function A_Callback(hObject, eventdata, handles)
function A_CreateFcn(hObject, eventdata, handles)
if ispc && isequal(get(hObject,'BackgroundColor'), get(0,'defaultUicontrolBackgroundColor'))
    set(hObject,'BackgroundColor','white');
function Z1_Callback(hObject, eventdata, handles)
function Z1_CreateFcn(hObject, eventdata, handles)
function Z2_Callback(hObject, eventdata, handles)
function Z2_CreateFcn(hObject, eventdata, handles)
function kc_Callback(hObject, eventdata, handles)
function kc_CreateFcn(hObject, eventdata, handles)
function k1_Callback(hObject, eventdata, handles)
function k1_CreateFcn(hObject, eventdata, handles)
function kr_Callback(hObject, eventdata, handles)
function kr_CreateFcn(hObject, eventdata, handles)
function hac_Callback(hObject, eventdata, handles)
function hac_CreateFcn(hObject, eventdata, handles)
function hfc_Callback(hObject, eventdata, handles)
function hfc_CreateFcn(hObject, eventdata, handles)
function c_Callback(hObject, eventdata, handles)
function c_CreateFcn(hObject, eventdata, handles)
function C1_Callback(hObject, eventdata, handles)
function C1_CreateFcn(hObject, eventdata, handles)
function d1_Callback(hObject, eventdata, handles)
function d1_CreateFcn(hObject, eventdata, handles)
function zuochimian_Callback(hObject, eventdata, handles)
Hx=findobj('tag','A');
A=str2num(get(Hx,'string'));
Hx=findobj('tag','Z1');
z1=str2num(get(Hx,'string'));
Hx=findobj('tag','Z2');
z2=str2num(get(Hx,'string'));
Hx=findobj('tag','kc');
kc=str2num(get(Hx,'string'));
Hx=findobj('tag','k1');
k1=str2num(get(Hx,'string'));
Hx=findobj('tag','kr');
kR=str2num(get(Hx,'string'));
Hx=findobj('tag','hac');
ha_c=str2num(get(Hx,'string'));
Hx=findobj('tag','hfc');
hf_c=str2num(get(Hx,'string'));
Hx=findobj('tag','c');
c_c=str2num(get(Hx,'string'));
Hx=findobj('tag','C1');
c2=str2num(get(Hx,'string'));
alfa=-0.6*pi/180;    %蜗轮螺旋角
i=z1/z2;   %传动比
d1=k1*A;   %蜗杆喉部分度圆直径
m=(2*A-d1)/z2;  %模数
ha=ha_c*m; hf=hf_c*m; c=c_c*m;  %齿顶高,齿根高,顶隙
df1=d1-2*(hf+c);  %蜗杆喉部齿根圆直径
da1=d1+2*ha;   %蜗杆喉部齿顶圆直径
d2=2*A-d1;    %蜗轮分度圆直径
da2=d2+2*ha;  %蜗轮齿顶圆直径
df2=d2-2*(hf+c);  %蜗轮齿跟圆直径
a2=da2/2*cos(alfa);
b2=da2/2*sin(alfa);
Z=ones(size(d))*rf1*sin(t);
%set(findobj('tag','text13'),'Visible',on);
shading interp; colormap(copper)
xlabel('\fontsize{20}\itz\rm_{1}\fontsize{18}/mm')
zlabel('\fontsize{20}\ity\rm_{1}\fontsize{18}/mm')
box off
hold off
for step=-1:3:11  %u - 滚子高度参数
    u=step*c;    %u - 滚子高度参数
fai2=linspace(-3*2*pi*i,3.08*2*pi*i,500);  %fai2 - 蜗轮转角
fai1=fai2/i;   %fai1 - 蜗杆转角
e1=sin(-alfa)*(i*b2-c2*cos(fai2))+cos(-alfa)*(c2*sin(fai2)-i*a2);
e2=sin(fai2)*(u*sin(-alfa)+b2)+cos(fai2)*(u*cos(-alfa)-a2)+A;
tan_theta=e2./e1;
theta=-abs(atan(tan_theta));
x0=R*cos(theta);
y0=R*sin(theta);
z0=u*ones(size(fai1));
x1=-x0.*sin(fai1)+y0.*(cos(fai1).*sin(fai2)*cos(-alfa)-cos(fai1).*cos(fai2)*sin(-alfa))-a2.*cos(fai1).*cos(fai2)+b2.*cos(fai1).*sin(fai2)-c2.*sin(fai1)+A.*cos(fai1)+z0.*(cos(fai1).*cos(fai2)*cos(-alfa)+cos(fai1).*sin(fai2)*sin(-alfa));
y1=-x0.*cos(fai1)+y0.*(sin(fai1).*cos(fai2)*sin(-alfa)-sin(fai1).*sin(fai2)*cos(-alfa))+a2.*sin(fai1).*cos(fai2)-b2.*sin(fai1).*sin(fai2)-c2.*cos(fai1)-A.*sin(fai1)-z0.*(sin(fai1).*cos(fai2)*cos(-alfa)+sin(fai1).*sin(fai2)*sin(-alfa));
z1=-y0.*(sin(fai2)*sin(-alfa)+cos(fai2)*cos(-alfa))-a2*sin(fai2)-b2*cos(fai2)+z0.*(sin(fai2)*cos(-alfa)-cos(fai2)*sin(-alfa));
x1=cos(fai1).*cos(fai2).*(A*cos(fai2)+z0*cos(-alfa)-y0*sin(-alfa)-a2)+...
   cos(fai1).*sin(fai2).*(b2+y0*cos(-alfa)+z0*sin(-alfa)+A*sin(fai2))-...
   sin(fai1).*(c2+x0);
y1=sin(fai1).*cos(fai2).*(a2+y0*sin(-alfa)-z0*cos(-alfa)-A*cos(fai2))-...
    sin(fai1).*sin(fai2).*(b2+y0*cos(-alfa)+z0*sin(-alfa)+A*sin(fai2))-...
    cos(fai1).*(c2+x0);
z1=sin(fai2).*(A*cos(fai2)+z0*cos(-alfa)-y0*sin(-alfa)-a2)-cos(fai2).*...
    (b2+y0*cos(-alfa)+z0*sin(-alfa)+A*sin(fai2));
plot3(z1,y1,x1,'b');
hold on
jj=0;  %写文件用循环变量
for step_2=linspace(-3,3.5,300)   %step控制接触线疏密程度
    fai2=step_2*2*pi*i;    %fai2 - 蜗轮转角
jj=jj+1;
theta=-pi*(0:2000)/2000;
B4=sin(-alfa)*sin(theta)*(c2*cos(fai2)-i*b2)+...
    (i*a2-c2*sin(fai2))*sin(theta)*cos(-alfa)+...
    (A-a2*cos(fai2)+b2*sin(fai2))*cos(theta);
B5=i*sin(theta)-cos(theta)*(cos(fai2)*cos(-alfa)+sin(fai2)*sin(-alfa));
u=B4./B5;
S=(find(u>0&u<15)); %柱面参数u的边界条件
u=u(S);
theta=theta(S); %与u对应的theta
x0=R*cos(theta);
y0=R*sin(theta);
z0=u;    %u is a variable
x1=cos(fai1)*cos(fai2)*(A*cos(fai2)+z0*cos(-alfa)-y0*sin(-alfa)-a2)+...
   cos(fai1)*sin(fai2)*(b2+y0*cos(-alfa)+z0*sin(-alfa)+A*sin(fai2))-...
   sin(fai1)*(c2+x0);
y1=sin(fai1)*cos(fai2)*(a2+y0*sin(-alfa)-z0*cos(-alfa)-A*cos(fai2))-...
    sin(fai1)*sin(fai2)*(b2+y0*cos(-alfa)+z0*sin(-alfa)+A*sin(fai2))-...
    cos(fai1)*(c2+x0);
z1=sin(fai2)*(A*cos(fai2)+z0*cos(-alfa)-y0*sin(-alfa)-a2)-cos(fai2)*...
plot3(z1,y1,x1,'k');
end;
pushbutton5_Callback(hObject, eventdata, handles)
function youchimian_Callback(hObject, eventdata, handles)
kr=str2num(get(Hx,'string'));
c1=str2num(get(Hx,'string'));
i=z1/z2;   %传动比
d1=k1*A;   %蜗杆喉部分度圆直径
m=(2*A-d1)/z2;  %模数
d2=2*A-d1;    %蜗轮分度圆直径
a2=da2/2*cos(alfa);
b2=da2/2*sin(alfa);
c2=-c1
R=7;
rf1=A-df1/2;
t1=-pi/5.5;t2=pi/5.5;
t=linspace(t1,t2,60);
d=linspace(0,2*pi,60)';
e1=((A*ones(size(t)))-(rf1*(cos(t))));
e2=A*ones(size(t))-rf1*cos(t);
X=cos(d)*e1;
Y=sin(d)*e2;
mesh(Z,X,Y);
axis equal
axis off
ylabel('\fontsize{20}\itx\rm_{1}\fontsize{18}/mm')
box off
hold on
for step=-1:3:11;   %step控制螺旋线的稀疏程度和数量
fai2=linspace(-3.08*2*pi*i,3*2*pi*i,500);  %fai2 - 蜗轮转角
% e1=sin(fai2)*c2*cos(-alfa)-cos(fai2)*c2*sin(-alfa);
tan_theta=e2./e1;
theta=abs(atan(tan_theta));
theta=pi-theta;
x0=R*cos(theta);
y0=R*sin(theta);
z0=u*ones(size(fai1));   %u is a const
plot3(z1,y1,x1,'k')
hold on
jj=0;  %写文件用循环变量
for fai2=linspace(-3.5*2*pi*i,3*2*pi*i,300);  %fai2 - 蜗轮转角
jj=jj+1;
theta=pi*(0:2000)/2000;
        %theta赋初值,(0:pi)表示母面的左半侧,包络成蜗杆左齿面
B5=i*sin(theta)-cos(theta)*(cos(fai2)*cos(-alfa)+...
u=B4./B5;
S=(find(u>-2&u<15)); %柱面参数u的边界条件
u=u(S);
x0=R*cos(theta);
y0=R*sin(theta);
   sin(fai1)*(c2+x0);
    cos(fai1)*(c2+x0);
end;
hold off
function quanchimian_Callback(hObject, eventdata, handles)
function pushbutton15_Callback(hObject, eventdata, handles)
function pushbutton16_Callback(hObject, eventdata, handles)
close all
function text13_ButtonDownFcn(hObject, eventdata, handles)
function text13_CreateFcn(hObject, eventdata, handles)
function text13_DeleteFcn(hObject, eventdata, handles)
function figure1_WindowButtonDownFcn(hObject, eventdata, handles)
function figure1_ResizeFcn(hObject, eventdata, handles)
function figure1_CreateFcn(hObject, eventdata, handles)
function uipanel1_CreateFcn(hObject, eventdata, handles)
function uipanel1_ButtonDownFcn(hObject, eventdata, handles)
function figure1_KeyPressFcn(hObject, eventdata, handles)
还有untitled1的m文件程序如下
[[i] 本帖最后由 sigma665 于 2008-10-21 19:08 编辑 [/i]]
 楼主| 发表于 2008-10-20 18:32 | 显示全部楼层
function varargout = untitled1(varargin)
gui_Singleton = 1;
                   'gui_OpeningFcn', @untitled1_OpeningFcn, ...
                   'gui_OutputFcn',  @untitled1_OutputFcn, ...
if nargout
else
function untitled1_OpeningFcn(hObject, eventdata, handles, varargin)
function varargout = untitled1_OutputFcn(hObject, eventdata, handles)
function pushbutton5_Callback(hObject, eventdata, handles)
global A
global z1
global z2
global kc
global k1
global kR
global ha_c
global hf_c
global c_c
global c2
i=z1/z2;   %传动比
d1=k1*A;   %蜗杆喉部分度圆直径
m=(2*A-d1)/z2;  %模数
d2=2*A-d1;    %蜗轮分度圆直径
a2=da2/2*cos(alfa);
b2=da2/2*sin(alfa);
R=7;
tan_theta=e2./e1;
x0=R*cos(theta);
y0=R*sin(theta);
   sin(fai1).*(c2+x0);
    cos(fai1).*(c2+x0);
%axis([-50,50,-50,50,-100,100]);
hold on
jj=0;  %写文件用循环变量
jj=jj+1;
u=B4./B5;
u=u(S);
x0=R*cos(theta);
y0=R*sin(theta);
   sin(fai1)*(c2+x0);
    cos(fai1)*(c2+x0);
end;
rf1=A-df1/2;
e1=A*ones(size(t))-rf1*cos(t);
X=cos(d)*e1;
Y=sin(d)*e2;
set(gca,'XGrid','on');
set(gca,'YGrid','on');
set(gca,'ZGrid','on');
set(gca,'Box','on');
mesh(Z,X,Y);
box off
hold off
function figure2_CreateFcn(hObject, eventdata, handles)
function pushbutton1_Callback(hObject, eventdata, handles)
function pushbutton2_Callback(hObject, eventdata, handles)
function pushbutton3_Callback(hObject, eventdata, handles)
function pushbutton4_Callback(hObject, eventdata, handles)
开始只想做一个界面可是用mesh画图编译后总是把按钮覆盖的看不见了各文本框输入的数据是
A 为160
Z1=1
Z2=36
k*=0.35
k1=1.1
kr=7
ha*=0.8
hf*=0.8
C*=0.2
c=8
a=0.6
还有我想再建一个GUI 界面让图显示再untitled1这各界面里怎么实现
发表于 2008-10-21 06:48 | 显示全部楼层
又是重复贴,建议版主删除吧
发表于 2008-10-21 19:06 | 显示全部楼层
这么长,真吓人
基本没人看的,lz注意求助的技巧
发表于 2008-10-22 08:15 | 显示全部楼层
首先你得确保哪一块有问题,叫人看这么长的程序,估计真看的人不多
GMT+8, 2025-2-4 23:22 , Processed in 0.109672 second(s), 18 queries , Gzip On.
