查看: 1283|回复: 2
[综合讨论] 紧急求救:有关警告信息的解决问题
发表于 2008-10-17 10:22 | 显示全部楼层 |阅读模式
我在进行问题求解的时候,出现了如下的警告信息:
*** WARNING ***                         CP =     307.109   TIME= 17:17:03
Coefficient ratio exceeds 1.0e8 - Check results.
*** WARNING ***                         CP =     483.219   TIME= 17:20:00
There are 9058 positive pivots with ratios less than 1.E-13 indicating
a possible poorly conditioned stiffness matrix.
There are 1762 negative pivots with ratios greater than -1.E-13
indicating a possible poorly conditioned stiffness matrix.
哪位大侠能否指点一二?在下不甚感激!
发表于 2008-10-17 20:11 | 显示全部楼层
第一个警告可能是因为系统对某些单元有默认的尺寸限制
也许你有一个某一方向的尺寸远大于另一方向的尺寸
后面两个警告的原因不太好推断
 楼主| 发表于 2008-10-17 21:24 | 显示全部楼层
我是在做流固耦合进行模态分析时出现如上警告信息的,后面还有如下警告信息
*** WARNING ***                         CP =      93.953   TIME= 21:11:25
Lanczos recursions terminated after 3 vectors.  Apply a new shift
(FREQB) using MODOPT command and re-run for additional eigenvalues of
the problem.
There are no solutions in the selected range.
*** ERROR ***                           CP =      94.000   TIME= 21:11:25
Mode file does not exist.
很苦恼,不知道怎么解决。
GMT+8, 2025-1-28 00:11 , Processed in 0.092778 second(s), 17 queries , Gzip On.
