查看: 1264|回复: 1
[数字信号类] 动态时间间隔
发表于 2008-10-14 22:38 | 显示全部楼层 |阅读模式
请大家帮下忙?怎么产生间隔服从指数分布,幅度服从锐利分布的随机脉冲信号?
下面是我用s-函数写的程序,但是结果不正确,请大家帮忙看下。
(1)产生间隔为0.1,0.2,0.3,……,宽度为0.2的脉冲序列
function [sys,x0,str,ts] = my132(t,x,u,flag,T,r)
T=0;
r=0.1;
switch flag,
  case 0,
    [sys,x0,str,ts]=mdlInitializeSizes;
  case 1,
    sys=mdlDerivatives(t,x,u);
  case 2,
    sys=mdlUpdate(t,x,u);
  case 3,
    sys=mdlOutputs(t,x,u,T,r);
  case 4,
    sys=mdlGetTimeOfNextVarHit(t,x,u);
  case 9,
    sys=mdlTerminate(t,x,u);
  otherwise
    error(['Unhandled flag = ',num2str(flag)]);
function [sys,x0,str,ts]=mdlInitializeSizes
sizes = simsizes;
sizes.NumContStates  = 0;
sizes.NumDiscStates  = 0;
sizes.NumOutputs     = 1;
sizes.NumInputs      = 0;
sizes.DirFeedthrough = 1;
sizes.NumSampleTimes = 1;
sys = simsizes(sizes);
x0  = [];
str = [];
ts  = [0.01 0];
function sys=mdlDerivatives(t,x,u)
sys = [];
function sys=mdlUpdate(t,x,u)
sys = [];
function sys=mdlOutputs(t,x,u,T,r)
if t>=T&&t<=T+r
    sys =0;
elseif t>T+r&&t<=T+r+0.2
    sys=1;
else
    T=r+0.2+T;
    r=r+0.1;
function sys=mdlGetTimeOfNextVarHit(t,x,u)
sampleTime =1;
sys = t + sampleTime;
function sys=mdlTerminate(t,x,u)
sys = [];
(2)产生间隔为rand,宽度为0.2的脉冲。借助与(1)的思想,但运行的结果不正确,请大家把那个我看下,是不是方法错了。还又没有其他的方法
T=0;
r=rand;
switch flag,
  case 0,
  case 1,
  case 2,
  case 3,
  case 4,
  case 9,
  otherwise
sizes = simsizes;
x0  = [];
str = [];
ts  = [0.01 0];
sys = [];
sys = [];
if t>=T&&t<=T+r
    sys =0;
    sys=1;
else
    T=r+0.2+T;
    r=rand;
sampleTime =1;
sys = [];
请大家帮忙,感谢感谢!
 楼主| 发表于 2008-10-14 22:40 | 显示全部楼层
补充:(1)的程序是正确的只有(2)中又问题
GMT+8, 2024-11-25 09:57 , Processed in 0.065901 second(s), 18 queries , Gzip On.
