查看: 2079|回复: 1
一个错误,麻烦大家帮忙看看
发表于 2008-10-12 09:25 | 显示全部楼层 |阅读模式
  最近处理一个大型的齿轮箱,模型采用壳和实体单元混合建模,壳和实体单元采用shell-to-solid建模,有些网格区域采用tie连接,在提交运算时总是出现错误。错误信息如下:
  The factorizations in a row failed.Check the model.It is possible that the model contains the kinematic coupling definition set up in a way that a degree of freedom has neither mass or stiffness.
 楼主| 发表于 2008-10-17 18:04 | 显示全部楼层
自己顶一个,希望有知道的指导一下!谢谢
GMT+8, 2025-1-4 10:29 , Processed in 0.069330 second(s), 17 queries , Gzip On.
