查看: 2677|回复: 3
[工具箱] 在MATLAB里sample是一个函数吗?
发表于 2008-9-14 20:06 | 显示全部楼层 |阅读模式
在MATLAB里sample是一个函数吗?还是哪个工具箱里的?谁用过?
帮助里是这样解释的:
help sample
  To get started, select MATLAB Help or Demos from the Help menu.
SAMPLE  Sample/unsample linear systems
    [As,Bs,Ds,Ks,Ls] = SAMPLE(A,B,C,D,K,T,InterSample,Mode)
    A,B,C,D,K are the matrices of the system to be sampled/unsampled.
    T is the sampling interval.
    InterSample is 'zoh' or 'foh'
    Mode = 1 (default) means sampling and Mode = 0 means unsample.
    As,Bs,Cs,Ds,Ks are the resulting system matrices.
    Ls is the adjustment of the covariance matrix in case of 'foh'
    sampling, so that the covariance of the new innovations is
    Ls*Lambda*Ls' where Lambda is the T-adjusted covariance of the
    noise of the original system.
用数据试了试,不会用,能否帮帮忙,详细解释一下。
发表于 2008-9-14 21:14 | 显示全部楼层
就是对于ABCDKT确定的系统进行采样吧。没用过,而且对这个领域不熟,如果你是做这个课题的还是自己好好看看帮助吧。
 楼主| 发表于 2008-9-14 21:39 | 显示全部楼层
好的,我再仔细看看。
谢谢sogooda关注,祝你中秋节快乐!
发表于 2008-9-15 10:34 | 显示全部楼层
edit sample
看源代码
GMT+8, 2025-2-5 14:13 , Processed in 0.098658 second(s), 17 queries , Gzip On.
