查看: 831|回复: 0
[结构分析] 我这样做瞬态分析怎么会出现这种错误啊
发表于 2008-9-7 15:51 | 显示全部楼层 |阅读模式
下面是求解部分的命令流:
/solu
ANTYPE,TRANS
TRNOPT,FULL
CGOMGA,0
KBC,0
TIME,1
NSUBST,0.1
DCGOMG,0,2,0
OUTPR,ALL,ALL
OUTRES,ALL,ALL
LSWRITE,1
TIME,2
DCGOMG,0,0,0
OUTPR,ALL,ALL
OUTRES,ALL,ALL
LSWRITE,2
TIME,3
DCGOMG,0,-2,0
OUTPR,ALL,ALL
OUTRES,ALL,ALL
LSSOLVE,1,3,1
FINISH
算完了,系统却出现了下面的错误:the newton-raphson solution key has been activated for a structural analysis after the first load step.structral ananlyses must be run from the gegining with newton-raphson(NROPT command) if it is needed.
高手指点一下啊。先谢谢啦!
GMT+8, 2025-1-29 13:55 , Processed in 0.078454 second(s), 17 queries , Gzip On.
