下面是一个C语言写的例子
- #include <stdlib.h>
- #include "..\\Utils.h"
- #include "..\\TSPDataSet.h"
- #include "PSO.h"
- static void PSO_MendCycle( TParticle *Particle )
- int tLooper1, tLooper2;
- int HasFound;
- tLooper1 = 1;
- while( tLooper1 < Particle->Dimension )
- //查找是否有重复节点
- HasFound = 0;
- for( tLooper2=0; tLooper2<tLooper1; tLooper2++ )
- if( Particle->X[ tLooper2 ] == Particle->X[ tLooper1 ] )
- HasFound = 1;
- break;
- if( HasFound == 1 )
- Particle->X[ tLooper1 ] = ( Particle->X[ tLooper1 ] + 1 ) % Particle->Dimension;
- else
- tLooper1++;
- //适合度计算方法,必须定义
- static double PSO_GetFit( CTSPDataSet *dat, TParticle *Particle )
- int tResult = 0;
- tResult = dat->GetCycleLength( Particle->Dimension, Particle->X );
- return (double)tResult;
- //计算群体各个微粒适合度
- static void PSO_CalFit( CTSPDataSet *dat, TPSO *PSO )
- if(!PSO)
- return;
- for(int i=0; i<PSO->PNumber; i++)
- PSO->Particle[i].Fitness = PSO_GetFit( dat, &(PSO->Particle[i]));
- //初始化数据
- static void PSO_InitializeData( CTSPDataSet *dat, TPSO *PSO, int PNumber, int PDimension )
- if(!PSO)
- return;
- static int kk=(unsigned)time(NULL);
- srand((unsigned)time(NULL)+kk++);
- PSO->GBestIndex = 0;
- for(int i=0; i<PNumber; i++)
- for(int j=0; j<PSO->Particle[i].Dimension; j++)
- PSO->Particle[i].X[j] = (int)(rand()/(double)RAND_MAX*(PSO->Xup[j]-PSO->Xdown[j])+PSO->Xdown[j]);//初始化坐标
- PSO->Particle[i].Velocity[j] = rand()/(double)RAND_MAX*PSO->Vmax[j]-PSO->Vmax[j]/2;//初始化速度
- PSO_MendCycle(&(PSO->Particle[i]));
- for(j=0; j<PSO->Particle[i].Dimension; j++)
- PSO->Particle[i].XBest[j] = PSO->Particle[i].X[j];
- PSO->Particle[i].Fitness = PSO_GetFit( dat, &(PSO->Particle[i])); //计算该微粒适合度
- PSO->Particle[i].FitnessBest = PSO->Particle[i].Fitness; //设最优适合度初值
- if(PSO->Particle[i].Fitness<PSO->Particle[PSO->GBestIndex].Fitness)
- PSO->GBestIndex = i;//查找群体最优微粒
- //初始化数据结构
- static PSO_InitializeDataStruce( TPSO *PSO, int PNumber, int PDimension )
- int tLooper;
- PSO->GBestIndex = -1;
- PSO->PNumber = PNumber;
- PSO->PDimension = PDimension;
- PSO->Xup = CC_SAFE_MALLOC( PDimension, int );
- PSO->Xdown = CC_SAFE_MALLOC( PDimension, int );
- for( tLooper=0; tLooper<PDimension; tLooper++ )
- PSO->Xup[ tLooper ] = PDimension - 1;
- PSO->Xdown[ tLooper ] = 0;
- PSO->Vmax = CC_SAFE_MALLOC( PDimension, double );
- PSO->Vmax[ tLooper ] = ( PSO->Xup[ tLooper ] - PSO->Xdown[ tLooper ] ) * VelocityCoefficent;
- PSO->Particle = CC_SAFE_MALLOC( PNumber, TParticle );
- for( tLooper=0; tLooper<PNumber; tLooper++ )
- PSO->Particle[ tLooper ].Dimension = PDimension;
- PSO->Particle[ tLooper ].X = CC_SAFE_MALLOC( PDimension, int );
- PSO->Particle[ tLooper ].Velocity = CC_SAFE_MALLOC( PDimension, double );
- PSO->Particle[ tLooper ].XBest = CC_SAFE_MALLOC( PDimension, int );
- PSO->Particle[ tLooper ].Fitness = -1;
- PSO->Particle[ tLooper ].FitnessBest = -1;
- static void PSO_ReleaseDataStructure( TPSO *PSO )
- int tLooper;
- for( tLooper=0; tLooper<PSO->PDimension; tLooper++ )
- CC_FREE( PSO->Particle[ tLooper ].XBest, int );
- CC_FREE( PSO->Particle[ tLooper ].Velocity, double );
- CC_FREE( PSO->Particle[ tLooper ].X, int );
- CC_FREE( PSO->Particle, TParticle );
- CC_FREE( PSO->Vmax, double );
- CC_FREE( PSO->Xdown, int );
- CC_FREE( PSO->Xup, int );
- //微粒飞翔,产生新一代微粒
- static void PSO_ParticleFly( CTSPDataSet *dat, TPSO *PSO )
- static double FitBak[100];
- if(!PSO)
- return;
- static int tt=(unsigned)time(NULL);
- srand((unsigned)time(NULL)+tt++);
- //整个群体飞向新的位置
- //处理速度
- double tTemp;
- tTemp = (PSO->Particle[i]).Velocity[j];
- //tTemp = WEIGHT * tTemp;
- tTemp += rand()/(double)RAND_MAX*C1*(PSO->Particle[i].XBest[j]-PSO->Particle[i].X[j]);
- tTemp += rand()/(double)RAND_MAX*C2*(PSO->Particle[PSO->GBestIndex].XBest[j]-PSO->Particle[i].X[j]);
- (PSO->Particle[i]).Velocity[j] = tTemp;
- //检查速度最大值
- if(PSO->Particle[i].Velocity[j]>PSO->Vmax[j])
- PSO->Particle[i].Velocity[j] = PSO->Vmax[j];
- if(PSO->Particle[i].Velocity[j]<-PSO->Vmax[j])
- PSO->Particle[i].Velocity[j] = -PSO->Vmax[j];
- //粒子飞翔
- //修改坐标
- PSO->Particle[i].X[j] = (int)(PSO->Particle[i].Velocity[j] + PSO->Particle[i].X[j]) % PSO->Xup[j];
- //保护
- if(PSO->Particle[i].X[j]>PSO->Xup[j])
- PSO->Particle[i].X[j]=PSO->Xup[j];
- if(PSO->Particle[i].X[j]<PSO->Xdown[j])
- PSO->Particle[i].X[j]=PSO->Xdown[j];
- //对粒子飞翔后产生的新的个体进行修复
- PSO_MendCycle( &(PSO->Particle[i]) );
- //计算各微粒适合度
- PSO_CalFit( dat, PSO );
- for(i=0; i<PSO->PNumber; i++)
- FitBak[i] = PSO->Particle[i].Fitness;
- //设置新的个体最好位置
- if(PSO->Particle[i].Fitness<=PSO->Particle[i].FitnessBest)
- //设置新的最优个体
- if(PSO->Particle[i].FitnessBest<=PSO->Particle[PSO->GBestIndex].FitnessBest && i!=PSO->GBestIndex)
- //返回最佳个体
- static void PSO_GetBest( TPSO *PSO, int *elist )
- for(int i=0; i<PSO->Particle[PSO->GBestIndex].Dimension; i++)
- elist[i*2] = PSO->Particle[PSO->GBestIndex].XBest[i];
- elist[i*2+1] = PSO->Particle[PSO->GBestIndex].XBest[(i+1)%PSO->Particle[PSO->GBestIndex].Dimension];
- //主程序
- void PSO_Main( CTSPDataSet *dat, int PSONumber, int ecount, int *elist )
- TPSO *PSO;
- int counter=0;
- PSO = CC_SAFE_MALLOC( 1, TPSO );
- PSO_InitializeDataStruce( PSO, 20, ecount );
- PSO_InitializeData( dat, PSO, 20, ecount );
- do
- PSO_ParticleFly( dat, PSO );
- counter++;
- } while ( counter<PSONumber );
- PSO_GetBest( PSO, elist );
- PSO_ReleaseDataStructure( PSO );
- CC_FREE( PSO, TPSO );
来自于:http://blog.sina.com.cn/s/blog_48efb3e7010002sf.html |
