查看: 1434|回复: 2
[工具箱] 一道优化的题,过早的退出,
发表于 2008-8-27 20:55 | 显示全部楼层 |阅读模式
function maxtrans = transmissibility_zk(zk)
m1=260.8;
m2=14.5;
k1=334259;
z1 =0.03;
c1=2*sqrt(m1*k1)*z1;
z2=zk(1);
k2=zk(2);
c2=2*sqrt(k2*m2)*z2;
w1=0.5*2*pi;
w2=10*2*pi;
w = w1:(w2-w1)/500:w2;
T =( (c1*j*w + k1) .* (m2*(j*w).*2 + c2*j*w + k2) ) ./...
    ( (m1*(j*w).^2 +( c1 +c2 )*j*w +k1 + k2).*(m2*(j*w).^2 + c2*j*w +k2) - ( c2*j*w + k2).^2 );
% figure
% plot(w,abs(T))
% figure
% plot(w,angle(T)*180/pi)
maxtrans=max(abs(T));
这个是目标函数
以下是调用语句
[x,fval,exitflag,output,lambda,grad,hessian]=fmincon(@transmissibility_zk,[0.1,13865],[ ],[ ],[ ],[ ],[0.1,10000],[0.7,100000])
结果没有得到要求的目标值,
只迭代了6次就退出了
Optimization terminated: magnitude of directional derivative in search
direction less than 2*options.TolFun and maximum constraint violation
  is less than options.TolCon.
No active inequalities.
x =
  1.0e+004 *
   0.000036464769068   1.386498505477171
fval =
  11.592576914326367
exitflag =
     5
output =
       iterations: 6
        funcCount: 23
     lssteplength: 1
         stepsize: 0.001372954668234
        algorithm: 'medium-scale: SQP, Quasi-Newton, line-search'
    firstorderopt: 9.591579437255859e-004
          message: [1x172 char]
lambda =
         lower: [2x1 double]
         upper: [2x1 double]
         eqlin: [0x1 double]
      eqnonlin: [0x1 double]
       ineqlin: [0x1 double]
    ineqnonlin: [0x1 double]
grad =
  1.0e-003 *
   0.959157943725586
   0.537485388391948
hessian =
  18.401867691914799  -0.004367311374674
  -0.004367311374674   0.999885314836522
发表于 2008-8-27 21:01 | 显示全部楼层
在现有的优化限制条件下没有解,改一下限制条件吧
发表于 2008-8-29 11:00 | 显示全部楼层
如果用几个参数做fmincon优化,应该将这些优化求解的参数的数量级用新变量替换为一致,
在进行迭代的函数中还原计算。否则这个优化函数将得不到正确的优化解,你只会看到
一个变量有变化,另一个几乎不变。
用fminsearch优化函数就没有这个数量级的限制,但是不能提供上下界约束。
GMT+8, 2025-1-12 20:01 , Processed in 0.071332 second(s), 18 queries , Gzip On.
