查看: 1032|回复: 0
[混合编程] 求助:做COM组件时出现错误,求高手指点
发表于 2008-8-13 20:39 | 显示全部楼层 |阅读模式
小弟根据http://www.vckbase.com/document/viewdoc/?id=1489做COM组件的例子逐条编译,在编译前先设置系统环境变量,并使用mbuild -setup命令链接编译器,情况如下:
>> mbuild -setup
Please choose your compiler for building standalone MATLAB applications:
Would you like mbuild to locate installed compilers [y]/n? y
Select a compiler:
[1] Lcc C version 2.4.1 in C:\APPLICATION\MATLAB\sys\lcc
[2] Microsoft Visual C/C++ version 6.0 in D:\Program Files
[0] None
Compiler: 2
Please verify your choices:
Compiler: Microsoft Visual C/C++ 6.0
Are these correct?([y]/n): y
Warning: Mbuild requires that the Microsoft Visual C++ 6.0
directories "VC98" and "Common" be located within the same parent directory.
(Expected to find a directory named "Common" in the directory 'D:\Program Files'.)
Try to update options file: C:\Documents and Settings\Administrator\Application Data\MathWorks\MATLAB\R14SP3\compopts.bat
From template:              C:\APPLICATION\MATLAB\BIN\win32\mbuildopts\msvc60compp.bat
Done . . .
--> ""C:\Application\MATLAB\bin\win32\mwregsvr" "C:\Application\MATLAB\bin\win32\mwcomutil.dll""
DllRegisterServer in C:\Application\MATLAB\bin\win32\mwcomutil.dll succeeded
--> ""C:\Application\MATLAB\bin\win32\mwregsvr" "C:\Application\MATLAB\bin\win32\mwcommgr.dll""
DllRegisterServer in C:\Application\MATLAB\bin\win32\mwcommgr.dll succeeded
然后在command window中输入comtool命令,做COM组件,在添加*.m文件后生成COM组件的时候出现了如下错误:
请教各位高手,应该如何解决此问题!
GMT+8, 2025-1-12 22:51 , Processed in 0.062611 second(s), 21 queries , Gzip On.
