查看: 10643|回复: 5
[Nastran专区] NASTRAN计算磁盘空间不足问题?
发表于 2008-7-13 08:00 | 显示全部楼层 |阅读模式
请那位兄弟帮忙分析一下,是模型的问题还是机器设置的问题,不胜感激!
本次计算模型自由度为1194788,nastran界面提示需要内存171.5MB,磁盘11033.4MB。
计算盘里有30多G的空间。我已将SCRATCH文件移到计算盘目录F:下。F06文件提示磁盘空间不足,详细错误如下:
*** SYSTEM INFORMATION MESSAGE 6916 (DFMSYN)
     DECOMP ORDERING METHOD CHOSEN: BEND, ORDERING METHOD USED: BEND
*** USER WARNING MESSAGE 1249 (BIOWRT)
     STATUS =         6050, FILX =    1, LOGNAME = SCRATCH , NSBUF3 =    16896
     FILE = e:/scratch/cas1.T3184_17.SCRATCH
     BLKNBR =      63493
     WARNING MESSAGE IS --
     File mapping operation failed.  Standard I/O operations (ReadFile, WriteFile) will be used instead.
     磁盘空间不足。
*** USER FATAL MESSAGE 1250 (BIOWRT)
     STATUS =         6016, FILX =    1, LOGNAME = SCRATCH , NSBUF3 =    16896
     BLKNBR =      63550
     ERROR MESSAGE IS --
     Specified record is beyond maximum for this filesystem.
     BIOMSG: ERROR    923 HAS OCCURRED IN ROUTINE IONAST  , FILE INDEX =            1.
     LOGICAL NAME IS SCRATCH
     FILENAME IS e:/scratch/cas1.T3184_17.SCRATCH
     STATUS =       6016
********* NASTRAN FILE TABLE *********
INDEX  LOGNAME         STREAM_ID     NAME
     1  SCRATCH         00000001      e:/scratch/cas1.T3184_17.SCRATCH
     2  OBJSCR          00000002      e:/scratch/cas1.T3184_17.OBJSCR
     3  MASTER          00000003      e:/scratch/cas1.T3184_17.MASTER
     4  DBALL           00000004      e:/scratch/cas1.T3184_17.DBALL
     5  SCR300          00000005      e:/scratch/cas1.T3184_17.SCR300
     6  MASTERA         FFFFFFFA      d:/msc.software/msc.patran/2003r2/msc.nastran2001/msc2001/i386/SSS.MASTERA
     7  MSCOBJ          FFFFFFF9      d:/msc.software/msc.patran/2003r2/msc.nastran2001/msc2001/i386/SSS.MSCOBJ
*** SYSTEM FATAL MESSAGE 4276 (IONAST)
     ERROR CODE      923 PID=   0
     USER INFORMATION: THIS ERROR MAY BE CAUSED BY EXCEEDING THE CAPACITY OF A SYSTEM RESOURCE.
     (E.G., ALLOCATED DISK IS FULL, OR MAXIMUM FILE SIZE HAS BEEN REACHED)
*** USER INFORMATION MESSAGE 4276 (IONAST)
     TO OBTAIN A NASTRAN DUMP RESUBMIT JOB WITH DIAG 44 INSERTED IN THE EXECUTIVE CONTROL SECTION.
1                                        * * * END OF JOB * * *
发表于 2008-7-14 10:14 | 显示全部楼层
回复 楼主 的帖子
增大虚拟内存;或者检查你硬盘的文件格式是否是NTFS
 楼主| 发表于 2008-7-14 15:33 | 显示全部楼层
感谢楼主解答,我会试试!我原来计算用的是新配的机器出现问题,后来我又用原来的老机器算了一下,老机器内存1G,磁盘也小了不少反而能算了,不过计算时间长了很多。
发表于 2008-7-15 09:24 | 显示全部楼层
把你的fatal message 百度一下,就可以看到解决办法,求解时:
direct text input-》file management section中输入:
nastran system(151)=1
nastran system(1)=32769
在nastran求解控制中,输入scr=yes,选择不生成dball文件,节省磁盘空间。
 楼主| 发表于 2008-7-18 22:28 | 显示全部楼层
感谢各位朋友的指点!将磁盘格式由FAT32改为NTFS后可以计算了
发表于 2013-5-17 09:27 | 显示全部楼层
这两句话是什么意思
GMT+8, 2024-12-28 14:19 , Processed in 0.080235 second(s), 19 queries , Gzip On.
