查看: 1160|回复: 0
[材料与接触] 这个过盈接触分析为什么运行后就退出ansys界面?
发表于 2008-7-12 17:04 | 显示全部楼层 |阅读模式
程序如下:
/PREP7
ET,1,SOLID185
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,EX,1,,2.1e5
MPDATA,PRXY,1,,0.3
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,MU,1,,0.1
CYL4,0,0,0,0,110.1,90,186
CYL4,0,0,110,0,150,90,186
/VIEW, 1 ,1,1,1
/ANG, 1
/REP,FAST
FLST,3,1,6,ORDE,1
FITEM,3,1
VGEN, ,P51X, , , , ,186, , ,1
FLST,5,1,4,ORDE,1
FITEM,5,4
CM,_Y,LINE
LSEL, , , ,P51X
CM,_Y1,LINE
CMSEL,,_Y
LESIZE,_Y1, , ,15, , , , ,1
FLST,5,1,4,ORDE,1
FITEM,5,8
CM,_Y,LINE
LSEL, , , ,P51X
CM,_Y1,LINE
CMSEL,,_Y
LESIZE,_Y1, , ,25, , , , ,1
FLST,5,2,4,ORDE,2
FITEM,5,5
FITEM,5,-6
CM,_Y,LINE
LSEL, , , ,P51X
CM,_Y1,LINE
CMSEL,,_Y
LESIZE,_Y1, , ,10, , , , ,1
CM,_Y,VOLU
VSEL, , , ,       1
CM,_Y1,VOLU
CHKMSH,'VOLU'
CMSEL,S,_Y
VSWEEP,_Y1
CMDELE,_Y
CMDELE,_Y1
CMDELE,_Y2
SAVE
VPLOT
LPLOT
FLST,5,2,4,ORDE,2
FITEM,5,11
FITEM,5,13
CM,_Y,LINE
LSEL, , , ,P51X
CM,_Y1,LINE
CMSEL,,_Y
FLST,5,2,4,ORDE,2
FITEM,5,15
FITEM,5,17
CM,_Y,LINE
LSEL, , , ,P51X
CM,_Y1,LINE
CMSEL,,_Y
LESIZE,_Y1, , ,3, , , , ,1
FLST,5,2,4,ORDE,2
FITEM,5,18
FITEM,5,-19
CM,_Y,LINE
LSEL, , , ,P51X
CM,_Y1,LINE
CMSEL,,_Y
LESIZE,_Y1, , ,20, , , , ,1
CM,_Y,VOLU
VSEL, , , ,       2
CM,_Y1,VOLU
CHKMSH,'VOLU'
CMSEL,S,_Y
VSWEEP,_Y1
CMDELE,_Y
CMDELE,_Y1
CMDELE,_Y2
SAVE
SAVE
/UI,MESH,OFF
/COM, CONTACT PAIR CREATION - START
CM,_NODECM,NODE
CM,_ELEMCM,ELEM
CM,_KPCM,KP
CM,_LINECM,LINE
CM,_AREACM,AREA
CM,_VOLUCM,VOLU
/GSAV,cwz,gsav,,temp
MP,MU,1,0.4
MAT,1
MP,EMIS,1,7.88860905221e-031
R,3
REAL,3
ET,2,170
ET,3,174
R,3,,,0.1,0.1,0,
RMORE,,,1.0E20,0.0,1.0,
RMORE,0.0,0,1.0,,1.0,0.5
RMORE,0,1.0,1.0,0.0,,1.0
KEYOPT,3,4,0
KEYOPT,3,5,0
NROPT,UNSYM
KEYOPT,3,7,0
KEYOPT,3,8,0
KEYOPT,3,9,0
KEYOPT,3,10,2
KEYOPT,3,11,0
KEYOPT,3,12,0
KEYOPT,3,2,0
KEYOPT,2,5,0
! Generate the target surface
ASEL,S,,,9
CM,_TARGET,AREA
TYPE,2
NSLA,S,1
ESLN,S,0
ESLL,U
ESEL,U,ENAME,,188,189
ESURF
CMSEL,S,_ELEMCM
! Generate the contact surface
ASEL,S,,,3
CM,_CONTACT,AREA
TYPE,3
NSLA,S,1
ESLN,S,0
ESURF
ALLSEL
ESEL,ALL
ESEL,S,TYPE,,2
ESEL,A,TYPE,,3
ESEL,R,REAL,,3
/PSYMB,ESYS,1
/PNUM,TYPE,1
/NUM,1
EPLOT
ESEL,ALL
ESEL,S,TYPE,,2
ESEL,A,TYPE,,3
ESEL,R,REAL,,3
CMSEL,A,_NODECM
CMDEL,_NODECM
CMSEL,A,_ELEMCM
CMDEL,_ELEMCM
CMSEL,S,_KPCM
CMDEL,_KPCM
CMSEL,S,_LINECM
CMDEL,_LINECM
CMSEL,S,_AREACM
CMDEL,_AREACM
CMSEL,S,_VOLUCM
CMDEL,_VOLUCM
/GRES,cwz,gsav
CMDEL,_TARGET
CMDEL,_CONTACT
/COM, CONTACT PAIR CREATION - END
/MREP,EPLOT
SAVE
VPLOT
FINISH
/SOL
FLST,2,4,5,ORDE,4
FITEM,2,4
FITEM,2,-5
FITEM,2,10
FITEM,2,-11
DA,P51X,SYMM
FLST,2,1,5,ORDE,1
FITEM,2,8
/GO
DA,P51X,ALL,
SAVE
ANTYPE,0
ANTYPE,0
NLGEOM,1
NSUBST,60,10000,10
OUTRES,ERASE
OUTRES,ALL,1
AUTOTS,1
TIME,100
ASEL,S, , ,       2
NSLA,S,1
FLST,2,90,1,ORDE,4
FITEM,2,59
FITEM,2,-116
FITEM,2,813
FITEM,2,-844
/GO
D,P51X, ,-186, , , ,UZ, , , , ,
SAVE
/STATUS,SOLU
SOLVE
GMT+8, 2025-2-14 02:28 , Processed in 0.085732 second(s), 17 queries , Gzip On.
