查看: 2432|回复: 0
[基础理论] 运行cfx-5.6时出现的问提,大家帮个忙
发表于 2006-1-10 10:48 | 显示全部楼层 |阅读模式
我的机子上运行cfx-5.6时,点击cfx-pre后出现“The default font for this system is incompatible with cfx-pre.please select a new font from the following dialog box(this setting will be used for future sessions)<BR>(you can change this font in the 'edit ,,options' panel if your forms appear too large)<BR>这样的提示,好象是说我的系统的字体和cfx的不相容。<BR>然后就出现一个选择字体的dialog box让你选择。我不知道怎么办啊。<BR><BR><BR>还有一个问题是,点击cfx-post后,运行不了,出先cfx-post  exited with   returne  code 1,<BR>请大家帮个忙,小弟现在急得很
GMT+8, 2024-11-26 08:30 , Processed in 0.052763 second(s), 18 queries , Gzip On.
