查看: 1468|回复: 0
[控制系统类] 请教一个s函数的问题
发表于 2008-6-27 20:24 | 显示全部楼层 |阅读模式
本人在调用用s函数写的单神经元pid控制器时,出现一下错误:
Error in block 'untitled1/S-Function' while executing M-File S-function block 'sfuntmpl', flag = 2 (update), at time 0. MATLAB error message:
Error using ==> +
Matrix dimensions must agree
s函数如下:
function [sys,x0,str,ts] = pid(t,x,u,flag,deltaK)
%SFUNTMPL General M-file S-function template
%   With M-file S-functions, you can define you own ordinary differential
%   equations (ODEs), discrete system equations, and/or just about
%   any type of algorithm to be used within a Simulink block diagram.
%   The general form of an M-File S-function syntax is:
%       [SYS,X0,STR,TS] = SFUNC(T,X,U,FLAG,P1,...,Pn)
%   What is returned by SFUNC at a given point in time, T, depends on the
%   value of the FLAG, the current state vector, X, and the current
%   input vector, U.
%   FLAG   RESULT             DESCRIPTION
%   0      [SIZES,X0,STR,TS]  Initialization, return system sizes in SYS,
%                             initial state in X0, state ordering strings
%                             in STR, and sample times in TS.
%   1      DX                 Return continuous state derivatives in SYS.
%   2      DS                 Update discrete states SYS = X(n+1)
%   3      Y                  Return outputs in SYS.
%   4      TNEXT              Return next time hit for variable step sample
%                             time in SYS.
%   5                         Reserved for future (root finding).
%   9      []                 Termination, perform any cleanup SYS=[].
%   The state vectors, X and X0 consists of continuous states followed
%   by discrete states.
%   Optional parameters, P1,...,Pn can be provided to the S-function and
%   used during any FLAG operation.
%   When SFUNC is called with FLAG = 0, the following information
%   should be returned:
%      SYS(1) = Number of continuous states.
%      SYS(2) = Number of discrete states.
%      SYS(3) = Number of outputs.
%      SYS(4) = Number of inputs.
%               Any of the first four elements in SYS can be specified
%               as -1 indicating that they are dynamically sized. The
%               actual length for all other flags will be equal to the
%               length of the input, U.
%      SYS(5) = Reserved for root finding. Must be zero.
%      SYS(6) = Direct feedthrough flag (1=yes, 0=no). The s-function
%               has direct feedthrough if U is used during the FLAG=3
%               call. Setting this to 0 is akin to making a promise that
%               U will not be used during FLAG=3. If you break the promise
%               then unpredictable results will occur.
%      SYS(7) = Number of sample times. This is the number of rows in TS.
%      X0     = Initial state conditions or [] if no states.
%      STR    = State ordering strings which is generally specified as [].
%      TS     = An m-by-2 matrix containing the sample time
%               (period, offset) information. Where m = number of sample
%               times. The ordering of the sample times must be:
%               TS = [0      0,      : Continuous sample time.
%                     0      1,      : Continuous, but fixed in minor step
%                                      sample time.
%                     PERIOD OFFSET, : Discrete sample time where
%                                      PERIOD > 0 & OFFSET < PERIOD.
%                     -2     0];     : Variable step discrete sample time
%                                      where FLAG=4 is used to get time of
%                                      next hit.
%               There can be more than one sample time providing
%               they are ordered such that they are monotonically
%               increasing. Only the needed sample times should be
%               specified in TS. When specifying than one
%               sample time, you must check for sample hits explicitly by
%               seeing if
%                  abs(round((T-OFFSET)/PERIOD) - (T-OFFSET)/PERIOD)
%               is within a specified tolerance, generally 1e-8. This
%               tolerance is dependent upon your model's sampling times
%               and simulation time.
%               You can also specify that the sample time of the S-function
%               is inherited from the driving block. For functions which
%               change during minor steps, this is done by
%               specifying SYS(7) = 1 and TS = [-1 0]. For functions which
%               are held during minor steps, this is done by specifying
%               SYS(7) = 1 and TS = [-1 1].
%   Copyright 1990-2002 The MathWorks, Inc.
%   $Revision: 1.18 $
% The following outlines the general structure of an S-function.
switch flag,
  % Initialization %
  case 0,
    [sys,x0,str,ts]=mdlInitializeSizes;
  % Derivatives %
  % Update %
  case 2,
    sys=mdlUpdate(t,x,u,deltaK);
  % Outputs %
  case 3,
    sys=mdlOutputs(t,x,u);
  % GetTimeOfNextVarHit %
  % Terminate %
case {1,4,9} ,
    sys=[]
  % Unexpected flags %
  otherwise
    error(['Unhandled flag = ',num2str(flag)]);
% end sfuntmpl
% mdlInitializeSizes
% Return the sizes, initial conditions, and sample times for the S-function.
function [sys,x0,str,ts]=mdlInitializeSizes
% call simsizes for a sizes structure, fill it in and convert it to a
% sizes array.
% Note that in this example, the values are hard coded.  This is not a
% recommended practice as the characteristics of the block are typically
% defined by the S-function parameters.
sizes = simsizes;
sizes.NumContStates  = 0;
sizes.NumDiscStates  = 3;
sizes.NumOutputs     = 1;
sizes.NumInputs      = 4;
sizes.DirFeedthrough = 1;
sizes.NumSampleTimes = 1;   % at least one sample time is needed
sys = simsizes(sizes);
% initialize the initial conditions
x0  = [0.3*rand(3,1)];
% str is always an empty matrix
str = [];
% initialize the array of sample times
ts  = [-1 0];
% end mdlInitializeSizes
% mdlDerivatives
% Return the derivatives for the continuous states.
function sys=mdlDerivatives(t,x,u)
sys = [];
% end mdlDerivatives
% mdlUpdate
% Handle discrete state updates, sample time hits, and major time step
% requirements.
function sys=mdlUpdate(t,x,u,deltaK)
sys=x+deltaK*u(1)*u(4)*(2*u(1)-u(2));
% end mdlUpdate
% mdlOutputs
% Return the block outputs.
function sys=mdlOutputs(t,x,u)
xx=[u(1)-u(2)  u(1)  u(1)+u(3)-2*u(2)];
sys = u(4)+0.12*xx*x/sum(abs(x))
% end mdlOutputs
% mdlGetTimeOfNextVarHit
% Return the time of the next hit for this block.  Note that the result is
% absolute time.  Note that this function is only used when you specify a
% variable discrete-time sample time [-2 0] in the sample time array in
% mdlInitializeSizes.
function sys=mdlGetTimeOfNextVarHit(t,x,u)
sampleTime = 1;    %  Example, set the next hit to be one second later.
sys = t + sampleTime;
% end mdlGetTimeOfNextVarHit
% mdlTerminate
% Perform any end of simulation tasks.
function sys=mdlTerminate(t,x,u)
sys = [];
% end mdlTerminate
恳请哪位高人给予帮助,并解决这个问题!
GMT+8, 2024-11-29 02:08 , Processed in 0.072183 second(s), 17 queries , Gzip On.
