查看: 3134|回复: 2
[图像处理] 子函数 fuction 的使用方法
发表于 2008-6-22 01:20 | 显示全部楼层 |阅读模式
function [mssim, ssim_map] = ssim_index(img1, img2, K, window, L)
%SSIM Index, Version 1.0
%Copyright(c) 2003 Zhou Wang
%All Rights Reserved.
%The author is with Howard Hughes Medical Institute, and Laboratory
%for Computational Vision at Center for Neural Science and Courant
%Institute of Mathematical Sciences, New York University.
%Permission to use, copy, or modify this software and its documentation
%for educational and research purposes only and without fee is hereby
%granted, provided that this copyright notice and the original authors'
%names appear on all copies and supporting documentation. This program
%shall not be used, rewritten, or adapted as the basis of a commercial
%software or hardware product without first obtaining permission of the
%authors. The authors make no representations about the suitability of
%this software for any purpose. It is provided "as is" without express
%or implied warranty.
%This is an implementation of the algorithm for calculating the
%Structural SIMilarity (SSIM) index between two images. Please refer
%to the following paper:
%Z. Wang, A. C. Bovik, H. R. Sheikh, and E. P. Simoncelli, "Image
%quality assessment: From error visibility to structural similarity"
%IEEE Transactios on Image Processing, vol. 13, no. 4, pp.600-612,
%Apr. 2004.
%Kindly report any suggestions or corrections to zhouwang@ieee.org
%Input : (1) img1: the first image being compared
%        (2) img2: the second image being compared
%        (3) K: constants in the SSIM index formula (see the above
%            reference). defualt value: K = [0.01 0.03]
%        (4) window: local window for statistics (see the above
%            reference). default widnow is Gaussian given by
%            window = fspecial('gaussian', 11, 1.5);
%        (5) L: dynamic range of the images. default: L = 255
%Output: (1) mssim: the mean SSIM index value between 2 images.
%            If one of the images being compared is regarded as
%            perfect quality, then mssim can be considered as the
%            quality measure of the other image.
%            If img1 = img2, then mssim = 1.
%        (2) ssim_map: the SSIM index map of the test image. The map
%            has a smaller size than the input images. The actual size:
%            size(img1) - size(window) + 1.
%Default Usage:
%   Given 2 test images img1 and img2, whose dynamic range is 0-255
%   [mssim ssim_map] = ssim_index(img1, img2);
%Advanced Usage:
%   User defined parameters. For example
%   K = [0.05 0.05];
%   window = ones(8);
%   L = 100;
%   [mssim ssim_map] = ssim_index(img1, img2, K, window, L);
%See the results:
%   mssim                        %Gives the mssim value
%   imshow(max(0, ssim_map).^4)  %Shows the SSIM index map
if (nargin < 2 | nargin > 5)
   mssim = -Inf;
   ssim_map = -Inf;
   return;
if (size(img1) ~= size(img2))
   mssim = -Inf;
   ssim_map = -Inf;
   return;
[M N] = size(img1);
if (nargin == 2)
   if ((M < 11) | (N < 11))
       mssim = -Inf;
       ssim_map = -Inf;
      return
   window = fspecial('gaussian', 11, 1.5);    %
   K(1) = 0.01;                                % default settings
   K(2) = 0.03;                                %
   L = 255;                                 %
if (nargin == 3)
       mssim = -Inf;
       ssim_map = -Inf;
      return
   L = 255;
   if (length(K) == 2)
      if (K(1) < 0 | K(2) < 0)
        mssim = -Inf;
           ssim_map = -Inf;
           return;
   else
       mssim = -Inf;
       ssim_map = -Inf;
       return;
if (nargin == 4)
   [H W] = size(window);
   if ((H*W) < 4 | (H > M) | (W > N))
       mssim = -Inf;
       ssim_map = -Inf;
      return
   L = 255;
   if (length(K) == 2)
        mssim = -Inf;
           ssim_map = -Inf;
           return;
   else
       mssim = -Inf;
          ssim_map = -Inf;
       return;
if (nargin == 5)
       mssim = -Inf;
       ssim_map = -Inf;
      return
   if (length(K) == 2)
        mssim = -Inf;
           ssim_map = -Inf;
           return;
   else
       mssim = -Inf;
          ssim_map = -Inf;
       return;
C1 = (K(1)*L)^2;
C2 = (K(2)*L)^2;
window = window/sum(sum(window));
img1 = double(img1);
img2 = double(img2);
mu1   = filter2(window, img1, 'valid');
mu2   = filter2(window, img2, 'valid');
mu1_sq = mu1.*mu1;
mu2_sq = mu2.*mu2;
mu1_mu2 = mu1.*mu2;
sigma1_sq = filter2(window, img1.*img1, 'valid') - mu1_sq;
sigma2_sq = filter2(window, img2.*img2, 'valid') - mu2_sq;
sigma12 = filter2(window, img1.*img2, 'valid') - mu1_mu2;
if (C1 > 0 & C2 > 0)
   ssim_map = ((2*mu1_mu2 + C1).*(2*sigma12 + C2))./((mu1_sq + mu2_sq + C1).*(sigma1_sq + sigma2_sq + C2));
else
   numerator1 = 2*mu1_mu2 + C1;
   numerator2 = 2*sigma12 + C2;
   denominator1 = mu1_sq + mu2_sq + C1;
   denominator2 = sigma1_sq + sigma2_sq + C2;
   ssim_map = ones(size(mu1));
   index = (denominator1.*denominator2 > 0);
   ssim_map(index) = (numerator1(index).*numerator2(index))./(denominator1(index).*denominator2(index));
   index = (denominator1 ~= 0) & (denominator2 == 0);
   ssim_map(index) = numerator1(index)./denominator1(index);
mssim = mean2(ssim_map);
return
上面的子函数(附件课下载这个函数),使用
[mssim ssim_map] = ssim_index1('lena1.raw', 'lena.raw')
调用,却一直出来下面的结果,怎么回事呢?难道调用出错了吗 ?
mssim =
  -Inf
ssim_map =
  -Inf
发表于 2008-6-22 12:56 | 显示全部楼层
mssim =
  -Inf
ssim_map =
  -Inf
不是有结果吗
 楼主| 发表于 2008-6-22 19:44 | 显示全部楼层
回复 2楼 的帖子
恩,是的。
我之前对这个img参数理解的不正确,谢谢帮助
GMT+8, 2025-2-5 15:10 , Processed in 0.072077 second(s), 17 queries , Gzip On.
