查看: 5915|回复: 19
[FFT] 离散频谱校正--相位差法之改变窗长法(源程序)
发表于 2008-6-12 11:48 | 显示全部楼层 |阅读模式
第五贴,欢迎大家拍砖头阿,还请各位多多指教。
参考自丁康老师《离散频谱校正技术》一书和版主yangzj的相关贴子。
% Fs:采样频率  N:做谱点数  L:平移点数
clear all;clc
Fs=1024;N=1024;
t =(0:N-1)/Fs;
windowtype=input('请选择加窗类型1.矩形窗2.汉宁窗');
x=10.343*cos(2*pi*298.30453*t+135*pi/180);%.*hanning;%L+N点时间序列
if windowtype==1
    y1=fft(x,N);%对信号做N点FFT变换
    y2=fft(x,N/2);%对信号做N/2点FFT变换
elseif windowtype==2
    y1=fft(x.*hann(N)');%对信号做N点FFT变换
    y2=fft(x(1:N/2).*hann(N/2)');%对信号做N/2点FFT变换
else
    error('选择有误,请重新选择');
Y1=abs(y1(1:N/2)/N*2);%第一段信号幅值
Y2=abs(y2(1:N/4)/N*4);%第二段信号幅值
f=(1:N/2)*Fs/N;
subplot(211);
   if windowtype==1
        plot(f,Y1);
        xlabel('f');ylabel('A');title('加矩形窗校正前');grid on
        plot(f,2*Y1);
        xlabel('f');ylabel('A');title('加汉宁窗校正前');grid on
[Y1Amax,k1]=max(Y1);
[Y2Amax,k2]=max(Y2);
phase1=angle(y1(k1));
phase2=angle(y2(k2));
   if windowtype==1
        A_uncorrect=Y1Amax      %未校正幅值
        A_uncorrect=Y1Amax*2
f_uncorrect=(k1-1)*Fs/N         %未校正频率
phase_uncorrect=phase1*180/pi   %未校正相角
delt=mod(phase1-phase2,2*pi);
%将delt调整到(-pi,pi)之间
if delt<-pi
    delt1=delt+2*pi;
elseif delt>pi
    delt1=delt-2*pi;
else delt1=delt;
deltf=2*(k2-1)-(k1-1)-2*delt1/pi;
f_correct=(k1-1-deltf)*Fs/N     %校正后频率
phase_correct=(phase1+deltf*pi)*180/pi   %校正后相位
Y_correct=zeros(1,N/2);
if windowtype==1
    A_correct=Y1Amax/sinc(deltf)
    Y_correct(k1)=A_correct;
    f(k1)=f_correct;
    subplot(212);stem(f,Y_correct);grid on
    xlabel('f');ylabel('A');title('加矩形窗校正后');
    A_correct=2/sinc(deltf)*Y1Amax*(1-deltf^2)
    Y_correct(k2)=A_correct;
    f(k2)=f_correct;
    xlabel('f');ylabel('A');title('加汉宁窗校正后');
理论值
频率:298.30453幅值:10.343相位135
运行结果:
矩形窗
校正前        校正后
A_uncorrect =8.836556159610320                         A_correct =10.346244554887681
f_uncorrect =298                                                     f_correct =2.983047477837129e+002
phase_uncorrect =-1.701829534720524e+002      phase_correct =-2.250375545403775e+002
汉宁窗
校正前        校正后
A_uncorrect =9.730664267447002                         A_correct =10.334120533701167
f_uncorrect =298                                                     f_correct =2.983045300071315e+002
phase_uncorrect =-1.702381307852827e+002      phase_correct =-2.250535320689407e+002
发表于 2008-6-14 09:23 | 显示全部楼层
回复 楼主 的帖子
真是不错啊,正好用上,:victory:
发表于 2009-8-29 14:49 | 显示全部楼层
谢谢分享!
发表于 2009-12-22 21:20 | 显示全部楼层
谢谢分享。。。
正用呢
发表于 2010-10-25 09:50 | 显示全部楼层
非常感谢您的分享!向您的辛勤劳动表示敬意!
发表于 2011-3-29 10:55 | 显示全部楼层
回复 1 # zhaoyixu 的帖子
这种修正方法会使相位变化0.1弧度?这个范围是不是太大?有没有这种可能性?
发表于 2011-4-21 10:58 | 显示全部楼层
谢谢 正好要写谱分析的作业 用到 谢谢
发表于 2011-8-14 20:43 | 显示全部楼层
回复 1 # zhaoyixu 的帖子
理论值相位应该是135,但是实际校正后的相位225,比真实值差很多啊?
发表于 2011-8-14 21:52 | 显示全部楼层
回复 1 # zhaoyixu 的帖子
如果原始信号是由多个频率成分信号叠加的复杂信号,那么这个程序怎样修改呢?
发表于 2011-11-4 14:41 | 显示全部楼层
非常感谢您的分享!
发表于 2011-11-5 14:16 | 显示全部楼层
谢谢分享。。。
正用呢
发表于 2011-11-17 20:03 | 显示全部楼层
好像不适用频率叠加的信号啊
发表于 2011-12-15 19:18 | 显示全部楼层
回复 3 # weision 的帖子
正在学习频谱校正,谢谢了
发表于 2011-12-16 21:36 | 显示全部楼层
对于多频率信号,为什么求出来的结果只有第一个频率是正确的?
GMT+8, 2025-1-23 01:07 , Processed in 0.094588 second(s), 20 queries , Gzip On.
