查看: 1622|回复: 10
[Virtual.Lab] 耦合后的计算结果不对
发表于 2008-5-30 17:03 | 显示全部楼层 |阅读模式
我模拟的是在一个房间墙壁上面有一个点声源,在地面上有一排钢管
求在点源的激励作用下 房间内声场的分布
采用边界元的FLUID-FLUID模型
但是求解出来,发现管壁表面几乎不存在声压
请问大家这是怎么回事?
journal文件是这样的:
New Name '530wall' Model 1 File 530wall.sdb Return
Environment Section SETUP ANSYSREVISION '5.7' Return
Option  BEM Direct Collocation Element Interior Uncoupled Frequency  Return
Import Mesh Format Ansys File 529wall.cdb Return
Check Mesh Set Subdomain Return
Material Fluid
    Name 'air'
    Sound Real 3.4000e+002  Rho Real 1.2250e+000
    Return
Boundary Velocity  Real 0 Imag 0
    Elements Set 6
    Return
Boundary Impedance  Real 150 Imag 0
    Elements Set 6
    Return
Save Return
New Name '530tube' Model 2 File 530tube.sdb Return
Option  BEM Direct Collocation Element Exterior Uncoupled Frequency  Return
Import Mesh Format Ansys File 529_5tubes.cdb Return
Check Mesh Return
Material Fluid
    Name 'air'
    Return
    Elements All
    Return
Boundary Impedance  Real 46.5 Imag 0
    Elements All
    Return
Link
    Model 1
    Elements Set 1
    Elements Set 2
    Elements Set 3
    Elements Set 4
    Elements Set 5
    To
    Model 2
    Elements All
    Behavior FLUID-FLUID
    Return
Source Name 'spherical' Spherical
    Amplitude Real 0.001 Imag 0
    Position 3 0 0.5
    Return
Solve
    Frequency 300
    Return
发表于 2008-5-31 08:21 | 显示全部楼层
Link
    Model 1
    Elements Set 1
    Elements Set 2
    Elements Set 3
    Elements Set 4
    Elements Set 5
好像有问题。
    网格模型需要修改
 楼主| 发表于 2008-5-31 08:57 | 显示全部楼层
哦,这样......
我再改改
谢谢彭师兄!
 楼主| 发表于 2008-5-31 10:20 | 显示全部楼层
还是不行.....
我是这样改的
Link
    Model 1
    Elements Set 1
    To
    Model 2
    Elements Set 1
    Return
Link
    Model 1
    Elements Set 2
    To
    Model 2
    Elements Set 2
    Return
Link
    Model 1
    Elements Set 3
    To
    Model 2
    Elements Set 3
    Return
Link
    Model 1
    Elements Set 4
    To
    Model 2
    Elements Set 4
    Return
Link
    Model 1
    Elements Set 5
    To
    Model 2
    Elements Set 5
    Return
师兄能否给个建议?如何修改模型?
发表于 2008-5-31 13:12 | 显示全部楼层
Elements Set 1
    Elements Set 2
    Elements Set 3
    Elements Set 4
    Elements Set 5
是什么?  好像不是与Model 2 接触的单元吧。
需要与Model 2 接触的单元,这样才能耦合啊
 楼主| 发表于 2008-5-31 16:21 | 显示全部楼层
Elements Set 6 在modle1中是 墙壁
Elements Set 1、2、3、4、5 在两个模型中都是 管子
modle2的全体 与modle1中 对应的管子 相耦合
我是模仿的 轿车内噪声计算实例 做的
在 carbody modle里面 司机和乘客的座椅  都另外是两个单元集
然后分别与 单个的车座椅driver modle和passenger modle  进行耦合
我觉得这两个的思路 是一致的
[ 本帖最后由 lmy716 于 2008-5-31 16:52 编辑 ]
发表于 2008-6-2 10:26 | 显示全部楼层
是不一致的,钢管怎么能和海绵相比呢?你这个问题可以直接采用一个直接边界元模型求解,即将房间和钢管作为一个模型导入。还有重复定义
    Elements Set 6
    Return
    Elements Set 6
    Return
是没有意义的!
 楼主| 发表于 2008-6-2 10:58 | 显示全部楼层
明白了!:victory:
多谢!:@)
 楼主| 发表于 2008-6-2 17:07 | 显示全部楼层
又有一个问题
采用一个 直接边界元模型 求解,我设置 墙壁和管子 分别为两个set,但是,无法看到 管壁表面 声压大小。不知道是哪里还有错
发表于 2008-6-2 18:51 | 显示全部楼层
呵呵,你导入一个与管子重合的网格作为场点即可求解看到管壁表面声压大小啦。
 楼主| 发表于 2008-6-2 19:41 | 显示全部楼层
:@D 还是基本操作掌握得不好啊~
3Q3Q!!
GMT+8, 2025-1-26 20:53 , Processed in 0.091265 second(s), 21 queries , Gzip On.
