查看: 1074|回复: 0
[综合讨论] 错误分析问题 补充
发表于 2008-5-30 13:21 | 显示全部楼层 |阅读模式
Trouble solving algebraic loop containing 'xuyu1/SVR' at time 64.  Stopping simulation.  There may be a singularity in the solution.  If the model is correct, try reducing the step size (either by reducing the fixed step size or by tightening the error tolerances),请高手指出一下,谢谢高手,也谢谢titileaf解答呵
这是个滞后将近60s多的滞后,如果再把时间步长改小,这个建模就白做了
GMT+8, 2024-11-29 01:39 , Processed in 0.086334 second(s), 21 queries , Gzip On.
