查看: 1376|回复: 6
网络服务器用Hard Drive的一个振动实验要求实例
发表于 2008-5-29 03:51 | 显示全部楼层 |阅读模式
这里发一个Silicon Valley某著名服务器供应商对其使用硬盘的要求之一,不知道国内的硬盘厂家是否可以达到这个要求。下面只是Operating vibration部分,要求在整个约一小时10分钟的振动中数据读、写正常。要求在X,Y,Z三个方向别做,总共3个半小时。
Profile Parameters
profile 1
Profile name:        5-500Hz, 1.0Oct/Min, 10 Sweep
Profile Maximum Acceleration (Peak):        6.5000 G
Profile Maximum Velocity (Peak):        24.5792 In/s
Profile Maximum Displacement (Peak-Peak):        0.7824 In
Profile Table:
Frequency        Left Slope        Acceleration        Velocity        Displacement        Right Slope        High Abort        High Alarm        Low Alarm        Low Abort
Hz        dB/Oct        (G) Peak        (In/s) Peak        (In) Peak-Peak        dB/Oct
5.0                0.9        11.0606        0.704141        14.5901
6.0        14.5901        1.4        14.3378        0.760646        7.46448
8.0        7.46448        2        15.362        0.611234        18.7017
10.0        18.7017        4        24.5792        0.782379        -6.0206
20.0        -6.0206        2        6.14479        0.0977974        4.91919
25.0        4.91919        2.4        5.899        0.0751084        24.237
30.0        24.237        5        10.2413        0.108664        -16.8249
35.0        -16.8249        3.25        5.70588        0.0518925        6.45206
40.0        6.45206        3.75        5.76074        0.0458425        14.8407
50.0        14.8407        6.5        7.98823        0.0508546        -5.51644
60.0        -5.51644        5.5        5.63272        0.0298825        -12.6852
80.0        -12.6852        3        2.3043        0.0091685        20.7258
90.0        20.7258        4.5        3.0724        0.0108664        Const. Acce.
110.0        Const. Acce.        4.5        2.51378        0.00727419
120.0        -34.076        2.75        1.40818        0.00373532        Const. Acce.
200.0        Const. Acce.        2.75        0.844909        0.00134471
255.0        -15.021        1.5        0.361458        0.000451199        Const. Acce.
300.0        Const. Acce.        1.5        0.30724        0.000325991
350.0        -12.1136        1.1        0.193122        0.000175636        Const. Acce.
445.0        Const. Acce.        1.1        0.151894        0.00010865
500.0        -23.3513        0.7        0.0860271        5.47665e-005
Schedule Parameters
schedule 1
schedule name: Schedule1
Fwd Swp From 5.00Hz Btwn 5.00Hz And 500.00Hz for 10.00Sweeps at 1.00 Oct/Min
Save All Panes
Auto-Save Signals
发表于 2008-5-29 07:24 | 显示全部楼层
这个扫频图还够复杂的,贴出来欣赏。
发表于 2008-5-29 15:55 | 显示全部楼层
是不是写错了,5Hz,11个g,能实现吗?
发表于 2008-5-29 16:16 | 显示全部楼层
回复 3楼 的帖子
您看错了,是0.9g,11.0606是速度in/sec
发表于 2008-5-29 21:56 | 显示全部楼层
还真够复杂的,还好位移不大,带减振托吗,
 楼主| 发表于 2008-5-30 00:59 | 显示全部楼层
Reply to fyga
This is a real sample recently. It is requested to shaker. The response signal on hard drive normaly shoud be larger than this value on resonans point.
发表于 2008-6-1 17:17 | 显示全部楼层
这好像是国军标GJB150上的路振试验
GMT+8, 2025-1-11 17:48 , Processed in 0.060543 second(s), 21 queries , Gzip On.
