查看: 1024|回复: 1
[混合编程] 用matcom45 编写的程序调入VC出现问题
发表于 2008-5-25 21:00 | 显示全部楼层 |阅读模式
出现
fatal error C1083: Cannot open include file: 'matlib.h': No such file or directory
Generating Code...
matlib.h是从matlib安装目录中拷过来的。
// ExampleDlg.cpp : implementation file
#include "stdafx.h"
#include "Example.h"
#include "ExampleDlg.h"
#include "matlib.h"
#include "test1.h"
#ifdef _DEBUG
#define new DEBUG_NEW
#undef THIS_FILE
static char THIS_FILE[] = __FILE__;
#endif
// CAboutDlg dialog used for App About
class CAboutDlg : public CDialog
public:
CAboutDlg();
// Dialog Data
//{{AFX_DATA(CAboutDlg)
enum { IDD = IDD_ABOUTBOX };
//}}AFX_DATA
// ClassWizard generated virtual function overrides
//{{AFX_VIRTUAL(CAboutDlg)
protected:
virtual void DoDataExchange(CDataExchange* pDX);    // DDX/DDV support
//}}AFX_VIRTUAL
// Implementation
protected:
//{{AFX_MSG(CAboutDlg)
//}}AFX_MSG
DECLARE_MESSAGE_MAP()
CAboutDlg::CAboutDlg() : CDialog(CAboutDlg::IDD)
//{{AFX_DATA_INIT(CAboutDlg)
//}}AFX_DATA_INIT
void CAboutDlg::DoDataExchange(CDataExchange* pDX)
CDialog::DoDataExchange(pDX);
//{{AFX_DATA_MAP(CAboutDlg)
//}}AFX_DATA_MAP
BEGIN_MESSAGE_MAP(CAboutDlg, CDialog)
//{{AFX_MSG_MAP(CAboutDlg)
  // No message handlers
//}}AFX_MSG_MAP
END_MESSAGE_MAP()
// CExampleDlg dialog
CExampleDlg::CExampleDlg(CWnd* pParent /*=NULL*/)
: CDialog(CExampleDlg::IDD, pParent)
//{{AFX_DATA_INIT(CExampleDlg)
  // NOTE: the ClassWizard will add member initialization here
//}}AFX_DATA_INIT
// Note that LoadIcon does not require a subsequent DestroyIcon in Win32
m_hIcon = AfxGetApp()->LoadIcon(IDR_MAINFRAME);
void CExampleDlg::DoDataExchange(CDataExchange* pDX)
//{{AFX_DATA_MAP(CExampleDlg)
  // NOTE: the ClassWizard will add DDX and DDV calls here
//}}AFX_DATA_MAP
BEGIN_MESSAGE_MAP(CExampleDlg, CDialog)
//{{AFX_MSG_MAP(CExampleDlg)
ON_WM_SYSCOMMAND()
ON_WM_PAINT()
ON_WM_QUERYDRAGICON()
ON_BN_CLICKED(IDC_BUTTON1, OnButton1)
//}}AFX_MSG_MAP
END_MESSAGE_MAP()
// CExampleDlg message handlers
BOOL CExampleDlg::OnInitDialog()
CDialog::OnInitDialog();
// Add "About..." menu item to system menu.
// IDM_ABOUTBOX must be in the system command range.
ASSERT((IDM_ABOUTBOX & 0xFFF0) == IDM_ABOUTBOX);
ASSERT(IDM_ABOUTBOX < 0xF000);
CMenu* pSysMenu = GetSystemMenu(FALSE);
if (pSysMenu != NULL)
  CString strAboutMenu;
  strAboutMenu.LoadString(IDS_ABOUTBOX);
  if (!strAboutMenu.IsEmpty())
   pSysMenu->AppendMenu(MF_SEPARATOR);
   pSysMenu->AppendMenu(MF_STRING, IDM_ABOUTBOX, strAboutMenu);
// Set the icon for this dialog.  The framework does this automatically
//  when the application's main window is not a dialog
SetIcon(m_hIcon, TRUE);   // Set big icon
SetIcon(m_hIcon, FALSE);  // Set small icon
// TODO: Add extra initialization here
return TRUE;  // return TRUE  unless you set the focus to a control
void CExampleDlg::OnSysCommand(UINT nID, LPARAM lParam)
if ((nID & 0xFFF0) == IDM_ABOUTBOX)
  CAboutDlg dlgAbout;
  dlgAbout.DoModal();
else
  CDialog::OnSysCommand(nID, lParam);
// If you add a minimize button to your dialog, you will need the code below
//  to draw the icon.  For MFC applications using the document/view model,
//  this is automatically done for you by the framework.
void CExampleDlg::OnPaint()
if (IsIconic())
  CPaintDC dc(this); // device context for painting
  SendMessage(WM_ICONERASEBKGND, (WPARAM) dc.GetSafeHdc(), 0);
  // Center icon in client rectangle
  int cxIcon = GetSystemMetrics(SM_CXICON);
  int cyIcon = GetSystemMetrics(SM_CYICON);
  CRect rect;
  GetClientRect(&rect);
  int x = (rect.Width() - cxIcon + 1) / 2;
  int y = (rect.Height() - cyIcon + 1) / 2;
  // Draw the icon
  dc.DrawIcon(x, y, m_hIcon);
else
  CDialog::OnPaint();
// The system calls this to obtain the cursor to display while the user drags
//  the minimized window.
HCURSOR CExampleDlg::OnQueryDragIcon()
return (HCURSOR) m_hIcon;
void CExampleDlg::OnButton1()
  initM(MATCOM_VERSION);
  dMm(x); dMm(y);
  #line 1 "c:/matcom45/debug/test1.m"
  call_stack_begin;
_ x = colon(1.0,0.1,10.0);
  #line 2 "c:/matcom45/debug/test1.m"
_ y = sin(x);
  #line 3 "c:/matcom45/debug/test1.m"
_ plot((CL(x),y));
  call_stack_end;
  exitM();
// TODO: Add your control notification handler code here
恳请大家帮忙,多谢了!
 楼主| 发表于 2008-5-25 22:02 | 显示全部楼层
回复 楼主 的帖子
不好意思,刚发上去,找了资料就解决了,应该把#include "matlib.h"
#include "test1.h"
的全目录写上,改成
#include "c:\matcom45\lib\matlib.h"
#include "C:\matcom45\Debug\test1.h"
GMT+8, 2025-1-13 08:03 , Processed in 0.085489 second(s), 21 queries , Gzip On.
