查看: 1341|回复: 2
[综合讨论] 编制高斯噪声程序问题
发表于 2008-5-16 13:27 | 显示全部楼层 |阅读模式
谁有用matlab 自己产生的高斯分布噪声的程序啊??不是用自带函数生成的那种。。。。在这里先谢过了
发表于 2008-5-18 01:28 | 显示全部楼层
即便有大多也是基于matlab中的平均序列生成的
发表于 2008-5-18 11:37 | 显示全部楼层
我有用Fortran 编的,你改为matlab 吧
!! Function to Return a Gaussian Noise with Mean u and Variance g
Real Function GaussianNoise(u,g)
USE PORTLIB
Real u,g
Integer n
Real    b
n=12 ; b=0.0
do i=1,n
     b=b+RANDOM(0)
enddo
GaussianNoise = u+g*(b-n/2)
Return
End Function GaussianNoise
!! Function to Return a Gaussian Noise (0,1) based on Box-Muller Method ----
   Real Function Gasdev()
   USE PORTLIB
   USE MSFLIB
   Real x1, x2, x3, f1
   if( jf_set == 0 ) then
   10  x1 = 2.0 * RANDOM(0) - 1.0
          x2 = 2.0 * RANDOM(0) - 1.0
          x3 = x1 * x1 + x2 * x2
             if( x3 > 1.0 .OR. x3 == 0.0 ) goto 10
              f1 = SQRT( -2.0 * log( x3 ) / x3 )
              noise_set = x1 * f1
                jf_set = 1
                  GASDEV = x2 * f1
                 else
                 jf_set = 0
                GASDEV = noise_set
             endif
    Return
    End Function Gasdev
GMT+8, 2025-1-13 07:56 , Processed in 0.089993 second(s), 23 queries , Gzip On.
