查看: 1342|回复: 1
[其他相关] Control Method(Wind turbine)
发表于 2008-5-16 10:36 | 显示全部楼层 |阅读模式
To prevent wind turbines from overloading and to ensure that they have constant output, part of the power has to be throttled when the wind velocity exceeds nominal wind velocity. The following two principles are the most commonly used methods of controlling power output:
Stall control (aerodynamic turbulence): if the wind velocity exceeds a certain limit, the rotor blades are designed to cause a turbulence at the edge of the blade to limit speed. In active stall control, the pitch of the rotor blades can also be changed.
Pitch control: Electronics and hydraulics are used to infinitely adjust the pitch of each blade. This reduces the lift, so that the rotor continues to generate power at nominal capacity even at high wind speeds.
 楼主| 发表于 2008-5-16 10:37 | 显示全部楼层
Stall control (aerodynamic turbulence): 如何實現?
Pitch control如何實現?
具體原理在哪裡?
GMT+8, 2024-12-2 11:04 , Processed in 0.069522 second(s), 17 queries , Gzip On.
