查看: 1434|回复: 5
[编程技巧] 关于小波神经网络故障诊断程序错误在哪里?
发表于 2008-5-5 10:13 | 显示全部楼层 |阅读模式
clc
clear
%step 1=========================
%定义输入样本;
P1=[0.251 0.503 0.952 1.335
0.724 0.692 0.584 0.448
2.002 1.964 1.812 1.613
1.735 1.684 1.513 1.289
3.287 3.225 3.025 2.746
0.243 0.495 0.901 1.337
0.703 0.661 0.570 0.433
1.983 1.924 1.863 1.671
1.659 1.588 1.458 1.269
3.277 3.211 2.992 2.703
0.253 0.501 0.941 1.310
0.872 0.843 0.727 0.576
2.032 1.993 1.853 1.659
1.400 1.362 1.211 1.019
3.268 3.202 2.983 2.690
0.247 0.500 0.891 1.291
0.726 0.667 0.607 0.390
1.891 1.813 1.776 1.510
1.237 1.186 1.106 1.005
3.255 3.216 3.105 2.912
0.262 0.511 0.973 1.359
0.697 0.664 0.575 0.412
1.781 1.743 1.612 1.449
1.125 1.081 1.031 1.982
3.303 3.254 3.048 2.759
%归一化;
tt=max(P1');
for i=1:25
P(i,:)=P1(i,:)/tt(i);
mubiao1=[0 0 0 1
0 0 0 1
0 0 0 1
0 0 0 1
0 0 0 1
0 0 1 0
0 0 1 0
0 0 1 0
0 0 1 0
0 0 1 0
0 0 1 1
0 0 1 1
0 0 1 1
0 0 1 1
0 0 1 1
0 1 0 0
0 1 0 0
0 1 0 0
0 1 0 0
0 1 0 0
0 1 0 1
0 1 0 1
0 1 0 1
0 1 0 1
0 1 0 1
aerfa=1;eta=1;
%初始化连接权 wjh(输出层和隐层的连接权);whi(隐层和输出层的连接权);
%假设小波函数节点数为:H 个;样本数为 P;
%输出节点数为:J 个;输入节点数为:I 个;
H=10;%隐层节点数;
A=size(mubiao1);B=A(1);%样本数;
I1=size(P1);I=I1(2);%输入节点数;
J1=size(mubiao1);J=J1(2);%输出节点数; %初始化小波参数
b=0.9*rand(H,1);
a=rand(H,1);
%初始化权系数;
whi=rand(I,H);wjh=rand(H,J);
%阈值初始化;
b1=rand(H,1);
b2=rand(J,1);p=1;%将 p 初始化;
%保存的误差;
Err_NetOut=[];ppp=0;
flag=1;count=0;%count 为迭代的次数;
while flag>0
flag=0;
x=P(p,:);
mubiao=mubiao1(p,:);
%step 2=================================
xhp1=0;
for h=1:H
for i=1:I
xhp1=xhp1+whi(i,h)*x(i);
ixhp(h)=xhp1+b1(h);
xhp1=0;
for h=1:H
oxhp(h)=fai((ixhp(h)-b(h))/a(h));
%step 3====================================
ixjp1=0;
for j=1:J
for h=1:H
ixjp1=ixjp1+wjh(h,j)*oxhp(h);
ixjp(j)=ixjp1+b2(j);
ixjp1=0;
oxjp=[ixjp(1) ixjp(2) ixjp(3) ixjp(4)];
%step 6==保存每次误差=====
wuchayy=abs(oxjp-mubiao)/mubiao;
E_x=1/2*sumsqr(x);
Err_NetOut=[Err_NetOut wuchayy];%保存每次的误差;
Err_rate=Err_NetOut/E_x;
%Err_rate
%oxjp
%求 detaj ,detab2==================================
for j=1:J
detaj(j)=-(oxjp(j)-mubiao(j))*oxjp(j)*(1-oxjp(j));
for j=1:J
for h=1:H
detawjh(h,j)=eta*detaj(j)*oxhp(h);
detab2=eta*detaj;
%求 detah, detawhi detab1 detab detaa;========================
sum=0;
for h=1:H
for j=1:J
sum=detaj(j)*wjh(h,j)*diffai((ixhp(h)-b(h))/a(h))/a(h)+sum;
detah(h)=sum;
sum=0;
for h=1:H
for i=1:I
detawhi(i,h)=eta*detah(h)*x(i);
detab1=eta*detah;
detab=-eta*detah;
for h=1:H
detaa(h)=-eta*detah(h)*((ixhp(h)-b(h))/a(h));
%引入动量因子 aerfa,修正各个系数=========================
wjh=wjh+1*detawjh;
whi=whi+1*detawhi;
a=a+1*detaa';
b=b+1*detab';
b1=b1+1*detab1';
b2=b2+1*detab2';
%判断所有的样本是否计算完=============================
if p==B
count=count+1;
ppp=ppp+1;
error=0;
for i=1:length(Err_NetOut)
error=error+Err_NetOut(i);
wuchaquxian(ppp)=error;%记入个次误差;
Err_NetOut=[];
if (error<0.5|count>100)
disp('程序结束');
else
p=1;
flag=flag+1;
%disp('第一次训练完毕');
else
p=p+1;%计算下一组样本;
flag=flag+1;
%将训练好的网络用于故障诊断
p_test1=[0.254 0.491 0.912 1.383
         0.252 0.491 0.913 1.383
         0.253 0.491 0.914 1.383
         0.776 0.652 0.593 0.474
         0.776 0.651 0.590 0.473
         0.775 0.651 0.592 0.471
         2.003 1.938 1.807 1.660
         1.981 1.922 1.869 1.670
         1.606 1.551 1.482 1.331
         3.313 3.264 3.148 2.957
         3.263 3.212 3.038 3.818];
kkk=max(p_test1');
for i=1:17
p_test(i,:)=p_test1(i,:)/kkk(i);
ll=size(p_test);
for p=1:ll(1);
x=p_test(p,:);
xhp1=0;
for h=1:H
for i=1:I
ixhp(h)=xhp1+b1(h);
for h=1:H
ixjp1=0;
for j=1:J
for h=1:H
yuce(p,:)=oxjp;
disp('诊断结果');
disp(yuce);
p=1:ppp;
wuchaquxian
xlabel('迭代次数');
ylabel('误差');
plot(p,wuchaquxian)
%fai和diffai 的函数调用如下:
function y=diffai(t);
y = -1.75*sin(1.75*t).*exp(-(t.^2)/2)-t* cos(1.75*t).*exp(-(t.^2)/2);
function y=fai(t);
y = exp(-(t.^2)/2) * cos(1.75*t);
[ 本帖最后由 eight 于 2008-5-5 10:22 编辑 ]
发表于 2008-5-5 10:23 | 显示全部楼层
原帖由 yinyubo393 于 2008-5-5 10:13 发表
clc
clear
%定义输入样本;
0.243 0. ...
新手发帖前请先阅读置顶的会员守则!什么错误都不说,把代码一摆就完事的做法本论坛不欢迎
发表于 2008-5-5 10:27 | 显示全部楼层
clc
clear
%定义输入样本;
0.243 0. ...
结果是不是这样?
   NaN   NaN   NaN   NaN
   NaN   NaN   NaN   NaN
   NaN   NaN   NaN   NaN
 楼主| 发表于 2008-5-5 17:42 | 显示全部楼层
不好意思,下次一定注意,
错误是那样
发表于 2008-5-5 18:30 | 显示全部楼层
回复 4楼 的帖子
建议一行一行调试
发表于 2009-7-18 16:03 | 显示全部楼层
权值和阈值都有问题,迭代的时候调整权值阈值,按你的这个网络是调整最后一次输出得到
0 1 0 1时的权值和阈值,也就是说即使这个网络是对的,也会出现不管你输入什么,输出都是0 1 0 1
GMT+8, 2025-1-27 06:08 , Processed in 0.080998 second(s), 18 queries , Gzip On.
