查看: 1115|回复: 2
[综合讨论] 大家看这是什么问题?我花好长时间都没解决
发表于 2008-5-4 21:58 | 显示全部楼层 |阅读模式
Warning: The model 'untit' does not have continuous states, hence using the solver 'VariableStepDiscrete' instead of solver 'ode45'. You can disable this diagnostic by explicitly specifying a discrete solver in the solver tab of the Configuration Parameters dialog, or setting 'Automatic solver parameter selection' diagnostic to 'none' in the Diagnostics tab of the Configuration Parameters dialog.
 楼主| 发表于 2008-5-4 21:59 | 显示全部楼层
补充
这是我在用dspbuilder设计FIR滤波器,用signal compiler时产生的
发表于 2008-5-4 22:01 | 显示全部楼层
不是错误,上面已经很清楚的告诉你怎么改了,按照他说得改就可以了,不该应该没问题
GMT+8, 2024-11-25 10:42 , Processed in 0.096966 second(s), 18 queries , Gzip On.
