查看: 1347|回复: 3
[CFD及热分析] 平板加载温度分布
发表于 2008-4-28 15:23 | 显示全部楼层 |阅读模式
对一个矩形平板,温度分布通过建模已经得到,如何在ansys有限元模型中加载温度分布函数,从而获得应力分布啊~~~~~~
本人是菜鸟,刚看了ansys两天又两小时,恳请高手指点啊!!谢谢。
板长R=4.160m;高L=1.710m板线膨胀系数为 13.23×10-6m/m·℃;杨氏弹性模量1.88×1011Pa;泊松比0.26,导热系数50W/(m·k),认为温度只与高度有关,温度分布函数已经建模求得:
t=-3.1309y4+8.8505y3-40.924y2+126.94y+254.53.
我编程试了下,总是有问题,哪位高手做个示范啊(大约三四十行程序的样子),谢谢!!!
我的QQ:544627372...........................................
 楼主| 发表于 2008-4-28 15:30 | 显示全部楼层
help
先自己顶个,高手救我~~~~多谢
发表于 2008-4-30 18:14 | 显示全部楼层
A coupled-field analysis usually involves applying results data from one analysis as loads in a second analysis. For example, you can apply the nodal temperatures calculated in a thermal analysis as body loads in a structural analysis (for thermal strain). Similarly, you can apply magnetic forces calculated in a magnetic field analysis as nodal forces in a structural analysis. To apply such coupled-field loads, use one of the following: Command(s):  LDREAD
GUI:  Main Menu> Preprocessor> Loads> Define Loads> Apply> load type> From source
Main Menu> Solution> Define Loads> Apply> load type> From source
See the Coupled-Field Analysis Guide for details about how to use this command in different types of coupled-field analyses.
 楼主| 发表于 2008-5-4 15:44 | 显示全部楼层
QQQ
谢谢!问题基本解决~~
谢谢~
GMT+8, 2025-1-31 02:44 , Processed in 0.086462 second(s), 18 queries , Gzip On.
