查看: 1581|回复: 0
[综合讨论] initial output故障
发表于 2008-4-27 16:32 | 显示全部楼层 |阅读模式
The initial output of Outport 'zong/BG/Pdw' is set to [] which might cause unexpected initialization. If you want output port 3 of Subsystem 'zong/BG' to have the same initial value as the Outport source, 'zong/BG/baidong/Integrator3', please explicitly set this initial output value on 'zong/BG/Pdw'. To turn off this warning message, uncheck the Compatibility option "Check undefined subsystem initial output" in the Diagnostics page of the Configuration Parameters dialog.
谁见过类似的警告,他说的那个地方——初始值我看过了,我没看出什么端倪啊?怎么回事呢?谢谢高手的帮忙
GMT+8, 2024-11-29 04:52 , Processed in 0.055834 second(s), 17 queries , Gzip On.
