查看: 1311|回复: 9
[编程技巧] 遗传算法求解非线型方程的问题
发表于 2008-4-18 12:36 | 显示全部楼层 |阅读模式
我用遗传算法解非线性方程,求解5个变量,
其中系数矩阵非常大,总得不到理想的结果,
然后需要算出p(i)的值 i=1:10(其中 sum(p)=1)
麻烦各位大侠帮我看看哪里出问题了!
拜谢啊!!
fk =
  1.0e+011 *
  Columns 1 through 6
  -0.000000001591165  -0.000000001264206  -0.000000000867055  -0.000000000490284  -0.000000000095361   0.000000000295842
   0.000000253180606   0.000000160716363   0.000000076278847   0.000000025353490   0.000000002406974   0.000000010059968
  -0.000040285211850  -0.000020548657733  -0.000006811826251  -0.000001376812645  -0.000000052694515   0.000000378191614
   0.006410041911401   0.002642590128756   0.000617603691203   0.000078033470928   0.000001351497371   0.000015231521429
  -1.019943433795469  -0.341841290104528  -0.056847878951163  -0.004584811803819  -0.000034955602952   0.000643265345850
  Columns 7 through 10
   0.000000000671125   0.000000001058743   0.000000001428334   0.000000001798466
   0.000000046173895   0.000000113158376   0.000000204761177   0.000000323448103
   0.000003257815446   0.000012215607411   0.000029469059452   0.000058171051345
   0.000235631443805   0.001332500713797   0.004258937242707   0.010461867547892
   0.017452977836325   0.146923470381716   0.618256416507724   1.881531621994822
lb=[1 1 1 1 1]*(-1)
ub=[1 1 1 1 1]
options=optimset('largescale','off')
[X,fval,exitflag]=ga(@text1,5,[],[],[],...
                              [],lb,ub,[],options)
%目标函数
function funtionError=text1(X)
funtionError=...
[(sum(exp(-[X(1) X(2) X(3) X(4) X(5)]*fk))*F1...
        -fk(1,:)*(exp(-[X(1) X(2) X(3) X(4) X(5)]*fk))').^2+...
        -fk(2,:)*(exp(-[X(1) X(2) X(3) X(4) X(5)]*fk))').^2+...
(sum(exp(-[X(1) X(2) X(3) X(4) X(5)]*fk))*F3...
        -fk(3,:)*(exp(-[X(1) X(2) X(3) X(4) X(5)]*fk))').^2 + ...
(sum(exp(-[X(1) X(2) X(3) X(4) X(5)]*fk))*F4...
        -fk(4,:)*(exp(-[X(1) X(2) X(3) X(4) X(5)]*fk))').^2+...
(sum(exp(-[X(1) X(2) X(3) X(4) X(5)]*fk))*F5...
        -fk(5,:)*(exp(-[X(1) X(2) X(3) X(4) X(5)]*fk))').^2];
%理想的结果应该是
% X=[
%  -0.01149493659894
%   0.00085613654997
%  -0.00000088487795
%  -0.00000000851687
%   0.00000000010986
%求解p(1)-p(10)
  p=exp(-[X(1) X(2) X(3) X(4) X(5)]*fk)/...
[ 本帖最后由 sigma665 于 2008-4-18 12:58 编辑 ]
发表于 2008-4-18 16:31 | 显示全部楼层
非线型方程用1stopt求解会更好点
 楼主| 发表于 2008-4-18 16:39 | 显示全部楼层
1stopt不是特别熟悉。。说明书也不详细
主要是数据从文件输入不知道怎么搞,有没有专门介绍1stopt的资料?
发表于 2008-4-18 17:05 | 显示全部楼层
google一下,或者搜索版面,n多例子
 楼主| 发表于 2008-4-18 17:24 | 显示全部楼层
麻烦帮我看一下这个是什么问题?
发表于 2008-4-18 18:21 | 显示全部楼层
回复 5楼 的帖子
你把你的方程贴一下吧
发表于 2008-4-18 18:46 | 显示全部楼层
回复 楼主 的帖子
对于gads工具箱,你可以详细看看遗传操作及参数的选择等help文件,然后尝试不同的选项设置。
对于GA,不同的遗传操作,不同的参数,会带来差别很大的效果。
每种优化方法都有其优缺点,并不是适合所有的优化问题,这个是已经被大家公认的了。我觉得GA是目前使用最广,理论最成熟的现代优化算法,通过合理的操作,得到的结果还是很理想的。
 楼主| 发表于 2008-4-18 21:16 | 显示全部楼层
原帖由 sigma665 于 2008-4-18 18:21 发表
你把你的方程贴一下吧
其中fk=[
-123.401986666667, 15309.8526427374, -1909789.96410041,    239549341.560198,      -30214602491.039,
-87.6375305,             7741.2805593795,    -689528.27440591,       61952373.811834,        -5616144306.013,
-59.06265104918,     3586.5719185062,    -223770.00498736,      14320890.485566,        -937932650.125,
-28.439255018957,   879.2160346562,       -29081.78717329,       1013450.252394,         -36742842.333,
2.815480861073,      87.4964063986,         713.65902354,            16697.447204,             196487.477,
33.027548857143,    1173.1652538497,     44394.49294689,         1769229.311412,         7343630.493 ,
64.045056222222,   4201.7966978657,      282266.01166872,      19393922.004712,       1360598257.263,
93.538933217391,   8819.304635927,         838503.24465969,     80419975.012864,       7783014155.159,
127.24891,             16253.0044120957,       2083630.02919474,    268092890.315688,    34616841265.119,
173.02841,             29985.3187910965,      5204399.56611482,     904686543.289774,   157501253705.876]
[F1 F2 F3 F4 F5]=[1.05137753485  1957.02063533292   8214.58926666724   12077012.3703088   219286227.91329]
待解的方程。。
待解的方程。。
 楼主| 发表于 2008-4-18 21:42 | 显示全部楼层
我用1stOpt编了个程序(源码如下),可是调试运行的时候没反应
不知道怎么回事。。有用1stOpt的高手帮我看看啊。。
Title "maxtrix-qiujie";
Parameters x(1:5)[-1,1];
//Variable ;
Constant F(1:10,1:5)=[
173.02841,               29985.3187910965,        5204399.56611482,        904686543.289774,        157501253705.876];
Constant Fr(1:5)=[
   1.05137753485,
   1957.02063533292 ,
   8214.58926666724 ,
   12077012.3703088,
   219286227.91329];
StartProgram;
Var   i,j,k: integer;
     sum,p,q,Z: double;
Begin
sum:=0 ;
i:= 1;
j:= 1;
k:= 1;
for k := 1 to 5 do
   q(k):=0;
   Z=0;
  for i := 1 to 10 do
      for j:=1 to 5 do
         sum=F(i,j)*x(j)+sum;
      End;
      p(i)=exp(-sum);
      q(k)=p(i)*F(k,i)+q(k);
      Z=Z+exp(-sum);
  End;
FunctionResult:= Fr(k)*Z-q(k);
End;
EndProgram;
 楼主| 发表于 2008-4-20 23:08 | 显示全部楼层
1stOpt有高手嘛?帮忙看看吧
GMT+8, 2025-1-13 13:51 , Processed in 0.079843 second(s), 22 queries , Gzip On.
