查看: 1400|回复: 0
[工具箱] 高阶累积量工具箱参数设定
发表于 2008-4-14 21:49 | 显示全部楼层 |阅读模式
下了高阶累积量的工具箱,但是有些参数不会设定,
function   y_cum = cum4est (y, maxlag, nsamp, overlap, flag, k1, k2)
%CUM4EST Fourth-order cumulants.
%       Should be invoked via CUMEST for proper parameter checks
%       y_cum = cum4est (y, maxlag, samp_seg, overlap, flag, k1, k2)
%       Computes sample estimates of fourth-order cumulants
%       via the overlapped segment method.
%              y: input data vector (column)
%         maxlag: maximum lag
%       samp_seg: samples per segment
%        overlap: percentage overlap of segments
%          flag : 'biased', biased estimates are computed
%               : 'unbiased', unbiased estimates are computed.
%   k1,k2 : the fixed lags in C3(m,k1) or C4(m,k1,k2); see below
%   y_cum : estimated fourth-order cumulant slice
%           C4(m,k1,k2)  -maxlag <= m <= maxlag
%  Note: all parameters must be specified
这是工具箱前的参数,我做的是信号检测,用四阶累积量算法,不知道该怎样设定参数?
maxlag,overlap,
flag,samp_seg,k1,k2,
GMT+8, 2025-1-13 11:41 , Processed in 0.053746 second(s), 17 queries , Gzip On.
