查看: 825|回复: 0
[结构分析] 求助:钢管自应力钢管砼应力分析
发表于 2008-4-12 16:46 | 显示全部楼层 |阅读模式
问题描述:
作钢管自应力钢管砼分析,对钢管由常温(30度),加到60度,浇筑砼,钢管自然降温到30度,分析砼产生的应力第1、2、3主应力
Ansys建模:
选取1/4模型,砼用solid65单元,钢管用Solid45单元,加温度荷载用两种方式,一种用Bfv命令,直接让钢管降温30度分析结果,一种是采用两个载荷步,先将砼的Solid65单元杀死,给钢管的solid45加温度载荷,然后重新将Solid65单元激活,再计算,然后分析砼的应力,但发现两种计
算结果差异较大,显然第一种方法符合实际情况,不知问题出在哪里,请各位指教;还有本人刚学习Ansys,分析方法不知是得当,还请各位指教。
/prep7
/title,Anlyse of CFST
et,1,solid65
et,2,solid45
et,3,shell63
mp,ex,1,3.45e10
mp,prxy,1,0.2
mp,alpx,1,1.0e-5
mp,dens,1,2400
mp,ex,2,2.06e11
mp,prxy,2,0.3
mp,alpx,2,1.2e-5
mp,dens,2,7850
!建立物理模型
k , 1  ,0     ,1
k , 2  ,0.5   ,0.96
k , 3  ,1     ,0.84
k , 4  ,1.5   ,0.64
k , 5  ,2     ,0.36
k , 6  ,2.5   ,0
bspline,1,2,3,4,5,6
kdele,2,5,1
numcmp,all
wpoff,,1,
wprota,,,-90
cswpla,11,0
cyl4,,,0.016,90,,180
cyl4,,,0.096,90,0.016,180
cyl4,,,0.10,90,0.096,180
nummrg,all
numcmp,all
lesize,6,,,5,0.4
lesize,7,,,5,0.4
lesize,2,,,6
lesize,5,,,6
type,3
amesh,2
lesize,3,,,6
lesize,4,,,6
amesh,1
lesize,9,,,1
lesize,10,,,1
lesize,8,,,6
amesh,3
arsym,y,1,3,1,,0,0
nummrg,all
numcmp,all
wpcsys,-1,1
csys,0
type,1
mat,1
extopt,esize,90,0,
extopt,aclear,1
vdrag,1,2,4,5,,,1
type,2
mat,2
vdrag,3,6,,,,,1
nummrg,all
numcmp,all
finish
/solu
da,10,all
da,14,all
da,24,all
da,17,all
da,20,all
da,27,all
da,25,symm
da,18,symm
da,15,symm
da,9,symm
da,13,symm
da,23,symm
da,1,symm
da,2,symm
da,3,symm
da,4,symm
da,5,symm
da,6,symm
nlgeom,on                     !打开大变形开关
nropt,full                    !完全牛顿-拉普森迭代
time,30
nsubst,100
outres,all
!加温度载荷方法1
vsel,s,,,5,6
bfv,all,temp,-30
vsel,all
esel,all
nsel,all
solve
!加温度载荷方法2
esel,s,type,,1
ekill,all
allsel,all
tref,60
tunif,30
esel,all
nsel,all
solve
esel,s,type,,1
ealive,all
esel,all
nsel,all
solve
GMT+8, 2025-2-22 11:16 , Processed in 0.084002 second(s), 18 queries , Gzip On.
