查看: 1580|回复: 2
[CFD及热分析] 函数形式加载热源的问题!
发表于 2008-4-11 11:14 | 显示全部楼层 |阅读模式
加载热源时,函数表达式为exp(-1*({x}^2+{Y}^2)),请问X和Y的值还用定义吗?在哪定义啊?请教大家!谢谢!
发表于 2008-4-30 18:31 | 显示全部楼层
You can use the Function Tool to apply complicated boundary conditions on a model. The Function Tool has two parts: the Function Editor creates an arbitrary equation or function (multiple equations), and a Function Loader retrieves the functions and loads them as TABLE arrays. They are then applied to a model using the tabular boundary condition process described in Applying Loads Using TABLE Type Array Parameters.
You must define your function and load it as a TABLE array before you try to add it as a load. You can access the Function Editor either via Utility Menu> Parameters> Functions> Define/Edit, or via Main Menu> Solution> Define Loads> Apply> Functions> Define/Edit. You can access the Function Loader either via Utility Menu> Parameters> Functions> Read from file, or via Main Menu> Solution> Define Loads> Apply> Functions> Read file
 楼主| 发表于 2008-5-3 15:08 | 显示全部楼层
回复 2楼 的帖子
谢谢你!这个问题解决了,似乎不用定义X和Y了。:@)
GMT+8, 2025-1-31 02:39 , Processed in 0.076198 second(s), 17 queries , Gzip On.
