查看: 2891|回复: 0
[LabView] labwindows/cvi与matlab联合编程
发表于 2008-3-28 21:48 | 显示全部楼层 |阅读模式
本人变了一个程序,用labwindows/cvi调用matlab以解决小波去除噪声问题。程序运行后,能够正常启动matlab,并将其最小化,但是无法从labwindows/cvi——matlab传递数组。程序如下》
#include "Matlabsrvr.h"
#include "MATLABUtil.h"
#include <ansi_c.h>
#include <analysis.h>
#include <cvirte.h>
#include <userint.h>
#include "小波分析.h"
#include <utility.h>
#include <formatio.h>
static int panelHandle;
static CAObjHandle hMATLAB=0;
double *wave;
double *Noise;
double *PrimitiveWave;
int i;
int main (int argc, char *argv[])
        if (InitCVIRTE (0, argv, 0) == 0)
                return -1;        /* out of memory */
        if ((panelHandle = LoadPanel (0, "小波分析.uir", PANEL)) < 0)
                return -1;
        DisplayPanel (panelHandle);
        RunUserInterface ();
        DiscardPanel (panelHandle);
        return 0;
int CVICALLBACK DispPrimitGRAPH (int panel, int control, int event,        //用来显示波形,并且能正常显示
                void *callbackData, int eventData1, int eventData2)
        double phase,f;
        switch (event)
                case EVENT_COMMIT:
                        phase=0;
                        f=1.0/256;
                        Noise=malloc(1024*sizeof(double));
                        WhiteNoise(1024,1,1,Noise);
                        PrimitiveWave =malloc(1024*sizeof(double));
                        wave=malloc(1024*sizeof(double));
                        SineWave(1024,1,f,&phase, PrimitiveWave);
                        for(i=0;i<1024;i++)
                                wave= PrimitiveWave+Noise;
                        DeleteGraphPlot (panelHandle, PANEL_PGRAPH, -1, VAL_IMMEDIATE_DRAW);
                        PlotY (panelHandle, PANEL_PGRAPH, wave, 1024, VAL_DOUBLE, VAL_THIN_LINE, VAL_EMPTY_SQUARE, VAL_SOLID, 1, VAL_RED);
                        break;
        return 0;
int CVICALLBACK ExecuteFilter (int panel, int control, int event,  //在另一个图形窗空中显示去除噪声后的波形
   HRESULT stat;                      /*定义matlab打开状态*/
   double *matrixReal=NULL;
   double *matrixImag=NULL;
   unsigned dim1=2;
   unsigned dim2=2;
   double a[1024];
   int result=0;
   LPSAFEARRAY saReal=NULL;
   LPSAFEARRAY saImag=NULL;
        switch (event)
                case EVENT_COMMIT:
                         stat=MLApp_NewDIMLApp (NULL, 1, LOCALE_NEUTRAL,0, &hMATLAB);
                         MinMaxMATLAB(hMATLAB,0);//能够正常欲行
                         for(i=0;i<1024;i++)
                                 a=wave;
                        result=SendMatrix(hMATLAB,"a",(double*)a,NULL,1,1024);  //矩阵发送不成功
                         if (result!=SUCCESS)
                            MessagePopup("ERROR","Error in sending Matrix to matlab");
                                return 0;
                         result=RunMATLABCommand(hMATLAB,"xd=wden(a,'heursure','s','one',8,'sym8');");
                          MessagePopup("ERROR","Error in sending command to matlab");
                                 return 0;
                         result=GetMatrix(hMATLAB,"xd",&matrixReal,&matrixImag,&dim1,&dim2);
                          MessagePopup("ERROR","Error in Getting Matrix from matlab");
                                 return 0;
                        DeleteGraphPlot (panelHandle, PANEL_FGRAPH, -1, VAL_IMMEDIATE_DRAW);
                        PlotY (panelHandle, PANEL_FGRAPH, matrixReal, 1024, VAL_DOUBLE, VAL_THIN_LINE, VAL_EMPTY_SQUARE, VAL_SOLID, 1, VAL_RED);
                        break;
        return 0;
int CVICALLBACK close (int panel, int control, int event,
        switch (event)
                case EVENT_COMMIT:
                        QuitUserInterface (0);
                        break;
        return 0;
GMT+8, 2024-12-29 03:47 , Processed in 0.065090 second(s), 17 queries , Gzip On.
