查看: 1229|回复: 0
[分形与混沌] CC程序
发表于 2008-3-26 16:19 | 显示全部楼层 |阅读模式
clear
clc
close all
load D0603Normal29.mat                %%%%%加载一个数据
x2=x(1:3000,2);                        %%%%%%由于数据点数太多,我取了第二个人前面3000个点,根据吕金虎书上建议的点数
SamplingFre=500;                     %%%%%%%采样频率为500HZ
%%%%%%%%%%%%%%%%%%%%%%中间这段是滤波%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%
[b,a] = butter(5,0.75/(SamplingFre/2),'high'); %highpass Butterworth filter cutoff 0.75Hz,
y=filtfilt(b,a,x2);
m_vector=2:5;
sigma=std(y);
r_vector=sigma/2*[1:4];             %%%%%%%以上4-6都是根据吕金虎的书取m和r值
N=length(y);
max_d=200;     %%%%%定义最大延迟时间
S_mean_m_r_t=0;
S_mean_m_t=0;
delta_S_t=0;
S_mean_t=0;
checkMa=[];
tic
for t=1:max_d;%1:max_d;
    data=disjoint(y,N,t);   %%%%%将时间序列划分成t个子序列,data大小t行 * N/t列
    for i=1:length(m_vector);
        S_mean_m_r_t=0;
        S_m_t=0;
        for j=1:length(r_vector);
            S_m_r_t=0;
            m=m_vector(i);
            r=r_vector(j);
            for k=1:t;
                Y1=data(k,:)';    %%%%%Y1是列向量
                Y2=data(k,:);     %%%%%Y2是行向量
                C_I(1)=Correlation_Integral(1,Y1,r,t);     %%%%求C(1,y,r,t)
                X=reconstitution(Y2,m,t);             %%%%对子序列相空间重构
                C_I(2)=Correlation_Integral(m,X,r,t);   %%%%求C(m,y,r,t)
                S_m_r_t=(C_I(2)-C_I(1))+S_m_r_t;     %%%%%%求S(m,r,t)
                checkMa=[checkMa;C_I];
            S_m_t(j)=(1/t)*S_m_r_t;
            S_mean_m_r_t=S_m_t(j)+S_mean_m_r_t;
        S_mean_m_t=S_mean_m_r_t+S_mean_m_t;
        delta_S_m_t(i)=max(S_m_t)-min(S_m_t);
        delta_S_t=delta_S_m_t(i)+delta_S_t;
    %%%S_mean_t=S_mean_m_t+S_mean_t;
    S_mean(t)=(1/16)*S_mean_m_t;
    delta_S_meam(t)=(1/4)*delta_S_t;
    S_cor(t)=delta_S_meam(t)+abs(S_mean(t));
subplot(3,1,1)
plot(delta_S_meam);
subplot(3,1,2)
plot(S_mean);
subplot(3,1,3)
plot(S_cor);
toc
这个程序我市根据吕金虎书上的步骤写的,但是好像运行不出正确的结果,dealt_S_m不知道什么原因越来越大,都达到几十几百的,我就不知道这个问题出在哪里(请大家帮忙一起看看)?本来这个程序能运行,但被我改来改去,现在出现很多NAN。
GMT+8, 2025-1-10 02:32 , Processed in 0.070243 second(s), 17 queries , Gzip On.
